Hi All, this is one for the accountants as it will send everybody else to sleep! I've discovered that you need to run conversion routine 11073 when copying companies, otherwise only a few Business Entities (table BusEntity)are created rather than the 300 or so system ones that exist. Having done this and created a dynamic segment using the (system) sales territory entity, I have three questions:
1) Why does it say "updated manually" against the dynamic account in cofa maint?
2) Do I need to change any posting rules as a result of adding a (system) dynamic segment?
3) Does it matter whether I use the standard of extended posting rules to get the dynamic segment working?
All comments gratefully received.
