In E9 I setup my configuration Q and A session in a seperate .net application and used the E9 Business Objects to populate the pcInputValues and to execute the Method rules against them. We are now in the process of converting to E10 and well, things are a bit more challenging.
Here's the really simplified E9 steps:
GetConfigurationSequence
GetGeneratedConfiguration
For each ConfigSequence Row
GetQuoteValues, GetOrderValues or GetJobValues
For Each Value in Order, Quote or Job
If InputName == SomeValue
InputValue = SomeOtherValue
End if
Next
SaveQuoteConfiguration, SaveOrderConfiguration or SaveJobConfiguration
Next
In E10 I'm thinking of doing something along the lines of the following:
Using Erp.Proxy.BO.ConfigurationRuntimeImpl
ConfigurationSequenceDataSet seqDS = PrestartConfiguration(...);
PcValueDataSet valDS = StartPcValueConfiguration(...);
// Update Values as necessary
SavePCValueConfiguration
So my question is has anyone tried calling or have successfully ran a configuration session from outside of E10 using the E10 Business objects?
