E10 Job Traveler - Modify to Portrait Layout
This is a known problem in 10.0 & 10.1
In the job traveler report my report properties has it set to landscape but it always prints out in portrait
Epicor’s workaround for this is to print preview the job traveler, then print it from the there.
It will print out as landscape and no need to modify report.
Gary Wojtowicz
AJR Industries, Inc.
Has anyone successfully modified the job traveler from landscape to portrait?  I have modified all of the sub-reports to fit portrait as well as the main report.  I have also verified the settings on the main report.  The width of the report is 7.9"  The interactive size and page size are both set to be portrait size and left and right margins are .11.  It still seems to be stretching wider than 8.5 causing two pages to print.  Any ideas?
Bryan,
Ignore if you already tried this.
Right-click in the blue area out of the report form and take Report Properties (or something like that). You can set portrait mode there.
Joe
On Tue, May 31, 2016 at 10:48 AM, bryan.mischler@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><p><span></span></p>Has anyone successfully modified the job traveler from landscape to portrait?  I have modified all of the sub-reports to fit portrait as well as the main report.  I have also verified the settings on the main report.  The width of the report is 7.9&quot;  The interactive size and page size are both set to be portrait size and left and right margins are .11.  It still seems to be stretching wider than 8.5 causing two pages to print.  Any ideas?<p></p>
</div>
<div style="color:#fff;min-height:0;"></div>
