Hi All,
I'm working with Epicor on an issue in 9.05.702 that we've encountered.
In the meantime, I wanted to see if anyone else is having this problem.
I have a dashboard where the main BAQ shows on hand quantities and there
are a couple of other BAQs that show other relevant information related
to the part number by setting up a publisher and subscriber relationship
between the BAQs.
I added this dashboard to Part Tracker as an embedded dashboard using
the Sheet Wizard and using PartNum to bind the two.
For the most part, everything is working but when I clear the screen,
using the clear icon on the toolbar, I get an error that says "There is
no row at position -1".
Additionally, we are live on 9.04.507a and are using this same setup
without error. It's only when testing this in 9.05.702 are we seeing the
error.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
between the BAQs.
error.
