E9 - Customization: Which Form Event?
I had one in MES that triggered 3-4 times and needed to reduce the time so I
tried a boolean variable approach.
Something like this in the module level variable section:
Dim IsRun As Boolean = False
In the EpiViewNotification try something like this:
If IsRun = False Then
(Your Code)
IsRun = True
End If
This works great when you are opening and closing a form once per session.
If the form is open for multiple actions maybe you could reset IsRun to
false after a GetList or GetByID method...whatever makes sense in your
workflow.
As Bernie said, it is pretty benign with light code. If you have a lot
going on (like calling busy subroutines) it does make a difference.
Just some thoughts.
Ross
bw2868bond
Sent: Wednesday, April 07, 2010 2:16 PM
Subject: [Vantage] Re: E9 - Customization: Which Form Event?
It has a tendency to do that (the multiple times part) as long as you arent
making intensive queries as a result it seems pretty harmless.
I really haven't found a better way
--- In vantage@yahoogroups.com, Joe Rojas <jrojas@...> wrote:
> Thank you!
> This worked but I have a follow up question.
> I put a MessageBox in there to see when this code is triggered.
> As the part is loading and as you move from part to part, the code is
> executed 4 times.
> Is this just the nature of the beast or is there anything I can do to
> "streamline" this?
> My code is pretty quick but if it wasn't, this might add too much time.
> Of bw2868bond
> Sent: Wednesday, April 07, 2010 2:49 PM
> I typically use epidataview notification
> If eventtype is initialize and row count > -1 then you have data
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Joe
> Rojas <jrojas@> wrote:
> > Hi All,
> > I am creating a customization for the Part Maintenance form.
> > I would like to add code that triggers after part details are
> retrieved.
> > My code is dependent on a value in a specific field so the code would
> > need to be triggered after the data is loaded.
> > Which form event (is it a form event?) should I use?
> > A couple of scenarios that I can picture where the code needs to be
> > trigger is:
> > 1) Part form is opened, user enters or searches for a part number,
> > data is retrieved/loaded, code is triggered.
> > 2) A user selects more than one part number when searching, user
> > moves from one part to another, data is loaded, code is triggered.
> > Joe Rojas | Director of Information Technology | Mats Inc
> > dir: 781-573-0291 | cell: 781-408-1264 | fax: 781-341-5694
> > jrojas@ | www.matsinc.com Ask us about our clean, green and
> beautiful matting and flooring
> > This message is intended only for the individual named. If you are not
> the named addressee you should not disseminate, distribute or copy this
> e-mail. Please notify the sender immediately by e-mail if you have
> received this e-mail by mistake. Please note that any views or opinions
> presented in this email are solely those of the author and do not
> necessarily represent those of the company.
Hi All,
I would like to add code that triggers after part details are retrieved.
trigger is:
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
> Hi All,
> trigger is:
Thank you!
executed 4 times.
"streamline" this?
Of bw2868bond
> Hi All,
retrieved.
> trigger is:
It has a tendency to do that (the multiple times part) as long as you arent making intensive queries as a result it seems pretty harmless.
> Thank you!
> executed 4 times.
> "streamline" this?
> Of bw2868bond
> > Hi All,
> retrieved.
> > trigger is:
