V8.03x Customization Retrieve Event
Customization->Wizards Tab->Form Event Wizard Tab->
1) Select AfterAdapterMethod or BeforeAdapterMethod ( I would think
after AdapterMethod)
2) Select CustomerAdapter
Then is the code make a case for GetByID. Uncomment out the messagebox
line to see the method names if your not sure.
The following is the results.
Private Sub oTrans_customerAdapter_AfterAdapterMethod(ByVal sender As
object, ByVal args As AfterAdapterMethodArgs) Handles
oTrans_customerAdapter.AfterAdapterMethod
'// ** Argument Properties and Uses **
'// args.MethodName
'Add Event Handler Code
'MessageBox.Show(args.MethodName) ' use this to find method
Select Case args.MethodName
Case "Update"
Case Else
End Select
End Sub
Private Sub oTrans_customerAdapter_BeforeAdapterMethod(ByVal sender As
object, ByVal args As BeforeAdapterMethodArgs) Handles
oTrans_customerAdapter.BeforeAdapterMethod
'// args.MethodName, args.Cancel
Case "Update"
'Dim dRes As DialogResult = MessageBox.Show("Cancel Update?",
"Cancel", MessageBoxButtons.YesNo)
'If (dRes = DialogResult.Yes) Then
'args.Cancel = True
'Else
' 'Do Something Else
'End If
Case Else
End Select
End Sub
Of Randy Weber
Sent: Wednesday, September 30, 2009 9:26 AM
Subject: RE: [Vantage] V8.03x Customization Retrieve Event
Sorry, but I don't understand. I start with the form event wizard and
don't see a GetById event. Is this an event? Can you reply with sample
event trigger proedure. And where would I find this event if it's not in
the GUI?
Randy weber
Behalf
Of Dan Godfrey
Sent: Wednesday, September 30, 2009 11:23 AM
I would think the pre or post event for GetByID would work.
Behalf
Of randyweb
Sent: Wednesday, September 30, 2009 8:39 AM
Subject: [Vantage] V8.03x Customization Retrieve Event
I am trying to trigger some code when we first load or pull up a
customer in customer maintenance. I thought the Retrieve event would
work. I want it to trigger when a customer is selected either by
searching or by typing in the CustId, but the event does not trigger.
Which event triggers when a new record is retrieved, and if it's not the
retrieve event, what IS the retrieve event?
Private Sub CustomerEntryForm_Retrieve(ByVal args As
EpiRetrieveEventArgs) Handles CustomerEntryForm.Retrieve
messagebox.show("Retrieve Event")
End Sub
thanks in advance,
randy weber
I am trying to trigger some code when we first load or pull up a customer in customer maintenance. I thought the Retrieve event would work. I want it to trigger when a customer is selected either by searching or by typing in the CustId, but the event does not trigger.
Which event triggers when a new record is retrieved, and if it's not the retrieve event, what IS the retrieve event?
Private Sub CustomerEntryForm_Retrieve(ByVal args As EpiRetrieveEventArgs) Handles CustomerEntryForm.Retrieve
End Sub
thanks in advance,
randy weber
Of randyweb
End Sub
thanks in advance,
randy weber
the GUI?
Randy weber
Of Dan Godfrey
Behalf
Of randyweb
End Sub
thanks in advance,
randy weber
