E9 - Is it possible to add a reason code after Adjust Inventory
You'll be fine. Just make sure the Reason Code exists in the Reason table.
Tim Vonderhaar
Sent: Friday, October 19, 2012 1:16 PM
Subject: [Vantage] Re: E9 - Is it possible to add a reason code after Adjust
Inventory transaction
Thanks everyone for their input. I was hoping for a UI way to do this, but
can easily write a SQL update to add the InvAdjReason code. Just hate direct
updates without really knowing if there may be other connected tables that
need updating as a result.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Vic
Drecchio" <vic.drecchio@...> wrote:
> I know of no way to do this via the UI. But you could use an updatable BAQ
> (not positive the PartTran table is a candidate in E9 for updateable). Or,
> if you're SQL, do it from the MSSQL console (Update PartTran...).
Progress,
> you can use SQuirreL to update PartTran.
Behalf Of
> Tim Vonderhaar
> Sent: Friday, October 19, 2012 11:23 AM
> Subject: [Vantage] E9 - Is it possible to add a reason code after Adjust
> Pilot testing our GL setup, we have a case where we performed an ADJ-QTY
> transaction, but did not have our Reason Codes setup yet. This in turn
> produced a transaction which has defaulted to our Company's Inventory COS
> and WIP GL which is incorrect. We have not performed a Capture COS/WIP
> Activity, so I'm wondering if there is a way to correct/update the ADJ-QTY
> transaction to use a good reason code.
> Thanks,
> Tim
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2012.0.2221 / Virus Database: 2441/5341 - Release Date: 10/19/12
Pilot testing our GL setup, we have a case where we performed an ADJ-QTY transaction, but did not have our Reason Codes setup yet. This in turn produced a transaction which has defaulted to our Company's Inventory COS and WIP GL which is incorrect. We have not performed a Capture COS/WIP Activity, so I'm wondering if there is a way to correct/update the ADJ-QTY transaction to use a good reason code.
Tim
Other than reversing the adjustment and then redoing it, I don't think
there is a way to update a PartTran record.
Of Tim Vonderhaar
Tim
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
You could use a BPM or .P to edit the record. Just be careful mucking
around in parttran.
*John Driggers*
*Chief Data Wrangler*
*I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
*:: 904.404.9233
:: waffqle@...
:: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
> Of Tim Vonderhaar
> Thanks,
> Tim
> of the company.
if you're SQL, do it from the MSSQL console (Update PartTran...). Progress,
Tim Vonderhaar
Tim
Thanks everyone for their input. I was hoping for a UI way to do this, but can easily write a SQL update to add the InvAdjReason code. Just hate direct updates without really knowing if there may be other connected tables that need updating as a result.
> Tim Vonderhaar
> Thanks,
> Tim
