Hi Joe,
I've used the Memory Leak Tester in the past and yes we have some users who experience the "System of out Memory" error. I used the Tester to see if certain forms were unloaded from memory properly after you closed them out. We are running Epicor 905 701. I've found that if you have embedded dashboards in a Tracker form that it will cause a memory leak. What's weird is that the trackers will load and unload from memory if they are not attached to the menu system. Once the Tracker is attached to the menu system it will produce a memory leak. I contacted tech support about it. They know it's a bug, but have no plans of fixing it, I was told.
David
