E9 Product Configurator: Raising an alert or message box
>>On 04/28/2010 10:02 AM, Bill Jackson wrote:
>>> in an 'on-leave' script:
>>> Message "Warning: Side-Arm Force Less Than Min. Reqd Force ". (or
>>> similar)
I create a Status Input that displays error messages.
Another trick is to create a hidden mandatory field and if there are errors, empty the field so the user cannot move to the next page. If all is good, put "OK" into the field.
Mark W.
Is there a way to create a custom alert windows or message box in the
configurator?
We have two calculations for SQFT and we want to ensure that one is not
greater than the other.
If it is, we want to alert the user so that she/he can fix it.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-1264 | fax: 781-341-5694
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Â
Message "Warning:Â Side-Arm Force Less Than Min. Reqd Force ". (or similar)
--- On Wed, 4/28/10, Joe Rojas <jrojas@...> wrote:
Subject: [Vantage] E9 Product Configurator: Raising an alert or message box
Date: Wednesday, April 28, 2010, 9:46 AM
Â
configurator?
jrojas@matsinc. com | www.matsinc. com Ask us about our clean, green and beautiful matting and flooring
Thanks Bill.
I tried that and it didn’t work.
The syntax check was good but when the OnLeave fires, nothing happens.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Bill Jackson
Sent: Wednesday, April 28, 2010 10:02 AM
Subject: Re: [Vantage] E9 Product Configurator: Raising an alert or message box
Message "Warning: Side-Arm Force Less Than Min. Reqd Force ". (or similar)
--- On Wed, 4/28/10, Joe Rojas <jrojas@... <mailto:jrojas%40matsinc.com> > wrote:
From: Joe Rojas <jrojas@... <mailto:jrojas%40matsinc.com> >
configurator?
 Is it within a 'conditional' statement, like an 'if', etc ?
Â
Thta's how I use it, : if 'so-and-so' is true then do:
                                Message ....
                             end if.
Â
I am on Vantage 6.10.541, so there may be a different 'message' function to be used on newer versions, thoung I doubt it.
Â
  I know, in 4GL code, you have to use this syntax:
Â
 MESSAGE "warning!..." VIEW-AS ALERT-BOX.
                               Â
Subject: RE: [Vantage] E9 Product Configurator: Raising an alert or message box
Date: Wednesday, April 28, 2010, 11:39 AM
Â
Thanks Bill.
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of Bill Jackson
To: vantage@yahoogroups .com
--- On Wed, 4/28/10, Joe Rojas <jrojas@matsinc. com <mailto:jrojas% 40matsinc. com> > wrote:
From: Joe Rojas <jrojas@matsinc. com <mailto:jrojas% 40matsinc. com> >
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
configurator?
When I tried your original example and it didn’t work, I jumped to the 4GL Reference guide.
I am currently trying the follow with no success:
Message "Warning: Side-Arm Force Less Than Min. Reqd Force " VIEW-AS ALERT-BOX ERROR BUTTONS OK.
I do not have any conditional statement.
This is the only line of code in the OnLeave on one of my inputs.
Once I load the configurator (in test mode), I change the value in the input and tab out of it.
I do see that it “thinks” for a second but no Message Box pops up. :(
Sent: Wednesday, April 28, 2010 1:32 PM
Message ....
end if.
Thanks Bill.
configurator?
 Not sure, could be some type of 'configuration' thing in the Vantage setup (?)
Sorry I couldn't be more help.
Â
Date: Wednesday, April 28, 2010, 1:48 PM
Â
Message ....
end if.
MESSAGE "warning!... " VIEW-AS ALERT-BOX.
Thanks Bill.
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf Of Bill Jackson
configurator?
No problem.
I appreciate your help!
Sent: Wednesday, April 28, 2010 3:30 PM
Message ....
end if.
Thanks Bill.
configurator?
This no longer works in 8 or 9. It worked in 6 because the client was
also written in Progress.
In 8 and up your only option is to log these messages to a file. Check
out the OUTPUT statement in the openedge docs.
Brian Johnson -- Epi-Center <http://epi-ctr.com>
Director of Technical Services | direct: 413-531-2859
> similar)
> <mailto:jrojas%40matsinc.com>> wrote:
> From: Joe Rojas <jrojas@... <mailto:jrojas%40matsinc.com>>
> message box
> configurator?
Hi Brian!
Thanks for the answer.
I was hoping for a better one though. :)
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Brian Johnson
Sent: Thursday, April 29, 2010 9:40 AM
> similar)
> From: Joe Rojas <jrojas@... <mailto:jrojas%40matsinc.com> <mailto:jrojas%40matsinc.com>>
> message box
> To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> configurator?
