Use SQuirreL
It provides a SQL server like user interface.
1. Download from here: http://sourceforge.net/projects/squirrel-sql/files/1-stable/3.2.1/squirrel-sql-3.2.1-install.jar/download
2. Execute installation with all default options is OK.
3. Locate Squirrel Installation folder (C:\Program Files) and open the subfolder “Libâ€
4. Open the \\<server>\epicor\oe101b\java folder and copy all “.jar†files into the “Lib†folder above. Do not overwrite any duplicate files.
- Replace <server> above with your Vantage server’s name.
5. Open Squirrel
6. Click on “Drivers†and then the “+†button to Add a new driver.
- Name = “OpenEdgeâ€
- Example URL = “jdbc:datadirect:openedge://<server>:10001;DatabaseName=mfgsys†(Replace <server> with your Vantage server; do NOT change the port here)
- Website URL = leave blank
- Class Name: “com.ddtek.jdbc.openedge.OpenEdgeDriverâ€
7. Click OK to Save the Driver info
8. Add an Alias: Click on the Alias tab in the left column and Click on the “+†button to Add a new Alias
- Name = give it a name... ie, “Vantage TEST†or “Vantage LIVEâ€
- Driver = Choose “OpenEdge†(should have a blue checkmark)
- URL = Should be a copy of the “Example URL†in Step 6; verify. Still leave the Port alone.
- User Name and Password should both equal “sysprogressâ€
- Click the “Auto Login†checkbox
- Click on “Properties†button
- On the Schemas tab, for best performance, select “Load all and cache all schemasâ€
- Click on Driver Properties tab and check the “Use Driver Properties†box
- Click the “Specify†checkbox for each of the following and fill in the appropriate value:
- ServerName = your Vantage Server
- User = sysprogress
- password = sysprogress
- PortNumber = your ODBC port (8350 for Live, 8370 for Test, 8380 for Pilot) ***Version 8 ports… Check for Ver 9
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joe Rojas
Sent: Thursday, February 13, 2014 2:46 PM
Subject: [Vantage] E9: Tool to update Progress Table
I need to update a field in PORel to correct a mistake that someone made.
I know this can be extremely dangerous but I am confident this update will not create a problem. (Fingers crossed)
I don’t see the SQL tool for OpenEdge anymore and I remember someone mentioning another program to view/query/and possible update the OpenEdge tables.
Does anyone remember what program that was or what programs do others use to do this?
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
addr: 37 Shuman Ave | Stoughton | Ma | 02072-3734
jrojas@... | www.matsinc.com
Ask us about our clean, green and beautiful matting and flooring
[cid:7024d7.png@1bc2a4c7.4ebc39d7]
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
