Is there a way to edit the drop down pick list options for Part Type?
You mean the one that specifies if it is Purch, Mfg’d, or Kit?
If so, then probably not, as that field drives many other aspects. If you need other types, use a Userfield like Character01 to hold the value. Setup the possible values as User Codes, then you can add a drop down to the Part screen, which uses those codes to make the drop down list.
Thanks Calvin!
More often than not the Part Class will do the trick. For materials, using part classes for Finished Goods, Sub-Assemblies and Raw Materials allow for different inventory accounts for each class and can also be used in reporting. This will
make it more useful than trying to add part types.
You can also get more granular than that as well.
Charlie Smith
CRS Consulting Svcs
(860) 919-1708
