what about #2. I have some debug notes related to this , like connecting through telnet and all such - which may or may not apply ; but is there really just an easier way to see what is being sent .
Because OF COURSE, life wouldn’t be interesting if everything worked, right?
I don’t think it affects the sending part, but creating an email in custom code allows you to make it HTML - so it doesn’t look like an email from 1986.
Hmmm
1986 - we had a MRP system with 20 VDTs, 4 bit slice processors and maxxed out at 1024 bytes of memory, a 40 Mb hard drive that took a forklift to move
When email doesn’t work from a BPM, I recommend changing it to SYNCHRONOUS and retesting. You’re going to see a delay in sending the email as it doesn’t spawn a process to do it offline. But if it fails, sometimes it will give you a better message then.
Also, if it works synchronously but NOT asynchronously, then the issue is probably that you don’t have the BPM Action process running.
Yup. I had a Compuserve account in 1985 while working for PC Connection. We had JUST STARTED SELLING 3.5" HD diskettes for about $80/10pk. OH, the unlimited storage possibilities!
