Engineering workbench
Is there a way to search eng workbench for a specific part number?
Thanks in advance
When you go to Check out a part? Or look for parts that someone else already has checked out?
If you are comfortable in BAQs, then just whip up a temporary BAQ based on the ECORev table. Use table criteria to limit your results to the part number that you want. Make sure to add in GroupID to see who has it checked out. Add other fields from ECO Rev to see if the revision is approved, and the relevant dates.
If you don’t want to get into a BAQ, then you have to open Engineering Workbench, choose an ECO group, then you can search for parts checked out to that group.
