Epicor 9.05.607b
You could probably also get it working in an updatable dashboard as well..
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-4832
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jckinneman
Sent: Friday, December 14, 2012 10:59 AM
Subject: [Vantage] Re: EPICOR 9.05.607B
The file attachment process is done by Business Objects so you can accomplish this via a few different approaches. For example you can take a UD entry screen, customize it so you can pick part numbers and store them in the UD table. Then enter the name of the file you want to attach the files to. Next either using embedded customization or a BPM call the appropriate BOs to attach the file-names to the list of part in the UD table. If the UD table records are not needed for anything else you can delete the records in effect using the UD table as a temporary location.
You could have also used a standard ListBox to store the list of names while processing them, in this case you would need to use embedded customization instead of a BPM as the BPM wouldn't have access to the listbox.
To figure out what BOs to call, turn on Tracing and then attach a file to a part. This will be the process you have to minimic to attach files to other part.
At mentioned by another Service Connect can do it too as that has access to the BOs also.
If you understand the structure of the file attachment table you can also work directly with it. I'd recommend using the part adapter and its BOs that work with attachments though.
Jim Kinneman
Encompass Solutions, Inc.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Mary Horsey <mhorsey@...> wrote:
> I did not phrase my question correctly. I want to attach the same document to multiple parts at the same time without having to do this one by one. We have vendor information such as data sheets that needs to be attached to multiple parts. Right now we are attaching one by one. Does this make more sense?
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of jckinneman
> Sent: Thursday, December 13, 2012 4:46 PM
> Not sure what you mean, the same file can be attached to as many things as you like (orders, parts, receipts). Epicor standard file attachment mechanism only stores the location of the file, not the actual file.
> Jim Kinneman
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Mary Horsey <mhorsey@<mailto:mhorsey@>> wrote:
> > Hi,
> > We were wondering if there is any way to attach a file to more than one part? If so could someone let me know how you are doing it? Any help you could give would be greatly appreciated.
> > Sincerely,
> > Mary Horsey
> > Greene Rubber Company Inc
> > HR/Finance Manager
> > 20 Cross Street
> > Woburn, MA 01801
> > 781-497-1851 (p)
> > 781-937-7881 (f)
Hi,
Sincerely,
Mary Horsey
HR/Finance Manager
20 Cross Street
Woburn, MA 01801
781-497-1851 (p)
781-937-7881 (f)
Jim Kinneman
--- In vantage@yahoogroups.com, Mary Horsey <mhorsey@...> wrote:
> Hi,
> Sincerely,
> Mary Horsey
> HR/Finance Manager
> 20 Cross Street
> Woburn, MA 01801
> 781-497-1851 (p)
> 781-937-7881 (f)
Jim Kinneman
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Mary Horsey <mhorsey@...<mailto:mhorsey@...>> wrote:
> Hi,
> Sincerely,
> Mary Horsey
> HR/Finance Manager
> 20 Cross Street
> Woburn, MA 01801
> 781-497-1851 (p)
> 781-937-7881 (f)
We use a Service Connect. Our example is a shipping Truck emails a
signed packslip or Bill of Lading ... goes thru a few hoops and then
service connect attaches it to the proper Invoice with the heading that
matches.
Brenda
Of Mary Horsey
Sent: Friday, December 14, 2012 8:45 AM
Subject: RE: [Vantage] Re: EPICOR 9.05.607B
Jim Kinneman
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> Hi,
> Sincerely,
> Mary Horsey
> HR/Finance Manager
> 20 Cross Street
> Woburn, MA 01801
> 781-497-1851 (p)
> 781-937-7881 (f)
Jim Kinneman
> Jim Kinneman
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Mary Horsey <mhorsey@<mailto:mhorsey@>> wrote:
> > Hi,
> > Sincerely,
> > Mary Horsey
> > HR/Finance Manager
> > 20 Cross Street
> > Woburn, MA 01801
> > 781-497-1851 (p)
> > 781-937-7881 (f)
