in 607b we attached a phantom part to a physical part we are doing work on. This BOM was adding the operations that were needed to be done to it. We would select rev PP(containing a paint BOM) and that would add the operations of the paint process. Now when we create the job it doesn't carry over the operation, instead it adds the subassemblies to the job but we have to manually do Actions>Job>get details on the jobs for each part. The order job wizard should be doing that process for us but it is not. I still haven't heard back from epicor on whether this is an error on our side or theirs. I would think that there would be more issues with this if it was a production issue. If you happen to try it out please let me know if it works or not.
--- In vantage@yahoogroups.com, "kendramis" <Kendra@...> wrote:
> Thanks for the list, it has been helpful in our testing. Can you expand on what your issues were with Phantom BOMs on parts that doesn't seem to be working? We are working through testing now and I want to make sure we check this.
> Thanks
> Kendra Kalimanis
> --- In vantage@yahoogroups.com, "duckorz" <don.n.doan@> wrote:
> > We upgraded a week ago. 607b to 701. SQL64
> > 1. Projects with a sales order that have a deleted line won't open anymore. For example an order was created with lines 1,2,3,4. We go back and delete line 2. The project will think it's still there and wont load because it is looking for it. (Anyone else having problems with this? Epicor was able to recreate this error and I'm surprised no one has mentioned this one)
> > 2. Phantom BOM on parts doesn't seem to be working.
> > 3. Shipment entry doesn't work with One time ship, we have to save the address every time.
> > 4. Lost some report styles. AR/AP.
> > 5. Some customizations needed to be rebuilt/adjusted.
> > 6. Pretty much no performance improvement. Except for crystal reports
> > 7. I had to import a few customizations from our 701 test server, field positions got jumbled.
> > We are still testing to see what else we run into.
> > --- In vantage@yahoogroups.com, "Elizabeth" <gracefulthreads@> wrote:
> > > Dave,
> > > I've had the same issues with customization validation. So far I've had to rewrite about half... thankfully they aren't all that complicated.
> > > Also had same issues with various Report Styles and Data Definitions.
> > > I was talking with a tech before Christmas about an unrelated issue on our current 9.04.507A system and told him I was testing 701 now, he said I should wait before going live. I told him our projected go-live is mid-April, and he said that should do it.
> > > Ernie Lowell
> > > Diba Industries
> > > --- In vantage@yahoogroups.com, "DaveO" <daveolender@> wrote:
> > > > I see very litte here on 905.701 so I decided to post a few of the issues we are seeing in testing, hopefully to save you some headache time.
> > > > Here are a few "Heads Up" issues we have come across in our testing of 9.05.701. Note: we are NOT currently live so I cannot comment on performance issues since our test setup has fewer resources.
> > > > Background:
> > > > We are currently running 64bit W2K8R2 (virtual vSphere) and Progress 64bit.
> > > > We are upgrading from 9.05.606
> > > > 1. ALL Part Specific UOM's for our second company missing. I can't even get Epicor to answer my ticket on this one. We had to go into part master for all the part records that had a part specific UOM and re-enter the Conversion Factors.
> > > > 2. Customization Validate - hit or miss. Some screens that validated then generated errors when we tried to use them. I just re-imported them in and saved them and they work fine now.
> > > > 3. Inventory WIP/Reconciliation report known bug with Progress. Sometimes the report finishes, most time it just hangs in the system monitor until system is restarted.
> > > > 4. ARForm1 and ARForm2 datat definitions overwritten with "Test" setup.
> > > > 5. AR Invoice report styles 1001, 1002 and 1003 overwritten
> > > > 6. Had to rebuild BOL Data definitions.
> > > > 7. Had to add an explicit sort to Pack Slip. We were just taking the records in the XML order. However, 701 now changes the order (at least for Kit parts).
> > > > 8. Sales Order report style 1002 overwritten.
> > > > 9. Had to rebuild SubContract Packing slip Data definitions.
> > > > 10. Multi book - MultiGLJrn error after importing posting rules.
> > > > 11. EDI Direct import conversion - currently having problems with 850 import dealing with SDQ's. We get the first line, and multiple schedules but hangs trying to import the second Detail line. Again, Reported to Epicor - no meaningful answers or help at this time.
> > > > 12. Midwest EUG - customer that had issues with the Where Used quantities and quantities displayed for secondary plants.
> > > > Hope this helps someone,
> > > > DaveO
