Yes,
We had several reports modified (RDD dataset changes) and on our system we could not make changes to ANY of the existing data definitions. When we would make a change and add a new table to the RDD we would not get the data via the XML, just would not build the data structure at all.
At this point we have 6 – 7 one-offs from Epicor for each of our forms that got modified and they work very good.
As a note, Epicor changed something in the RDD generation of the data (SQL) and we now get the complete XML file within 4-5 seconds of submitting the job even if the RDD consists of 10-18 table joins – very happy with that performance
--- In vantage@yahoogroups.com, "jeffery_p_sanders" <jps@...> wrote:
> Motty,
> Did you have any issues with the Order Form?
> Jeff Sanders
> --- In vantage@yahoogroups.com, "mseal" <mseal@> wrote:
> > Jeff,
> > we have been working on 9.05.600C upgrade
> > regarding the Quote form, we found that none of the data definitions (RDD) could be modified.
> > wonder if you got a on-off from Epicor - we had them develop (i think) on-offs for 6 of our different business forms.
> > we did not have issues with the customizations. we are coming from 803 so some issues will not convert as tabs and we needed to re-create them.
> > Motty
> > --- In vantage@yahoogroups.com, "jeffery_p_sanders" <jps@> wrote:
> > > We upgraded from 9.04.506 to 9.05600C. We converted our production database and then copied it down to the Pilot database. I created a customization on the Order form and it works flawlessly in Pilot. I export from Pilot, import into Production and the VB fields do not update when the customization runs. It is like they are disabled or read-only. Has anyone experienced this problem?
> > > The only three major issues we have found so far are:
> > > 1. The quote form cannot be customized without a hot-fix from Epicor
> > > 2. During AP invoice entry you are unable to add a misc job charge without a hot-fix from Epicor.
> > > 3. The problem stated above.
> > > The permanent solutions will be out in the next major release. Scheduled for November.
> > > Jeff Sanders
