Do you know if there is a new conversion tool with the 9.05.700x or does it have a built in ability to allow the conversion from 8.03.409c? I'm trying the data upgrade utility now. I had to sign a paper from Epicor that I had been offered and refused their conversion services before they sent it to me. I can change my mind later on and purchase their conversion services if I choose to. The guide with the utility is missing quite a bit, although some of that may be due to the variety of ways people can set up for the conversion, anywhere from 1 to 3 servers, etc. So far I've found solutions to the errors I've received by searching this group. I'm not sure how much help I'd get from support because I'm using the utility without purchasing their services. Since we have no timeline for Epicor 9, I decided to try the utility before going the other route. I'm only about halfway thru the conversion now. I'm encouraged by your news of another option with 9.05.700x!
Sue
Sue
--- In vantage@yahoogroups.com, "Lisser, Jennifer" <Jennifer.Lisser@...> wrote:
> If you have the luxury, I would wait until 9.05.700x comes out (700 end of March target, wait until at least the first service pack because 700 has a lot of changes including a schema update). You have to convert to 409c first, but then can go right to 9.05.700. The DUU requires both a 9.04 and a 9.05 license but you can get that ahead of time, at least you aren't installing multiple Open Edge & Epicor versions for the DUU.
> We're going live on 9.05.607b, so I have to go to 409c, then 604 using the DUU, then to 607b. The DUU is only for 32-bit and we want to go live on 64-bit so I need 3 servers; but if I could wait until 700 then it would just be a matter of backing up my database on the 32-bit machine and restoring it to the 64-bit one.
