Thanks Rob,
When I get done playing with this converted db in E9, I'll contact Brad before I run another conversion. I discovered how wonderful the destructions were pretty quickly. I think I found the correct sequence between lots of time searching the group and some trial and error. Obviously I missed something somewhere. I didn't know if anyone at Epicor could help or if they've given up on the utility. I'd be willing to try again if it would save me some conversion time!
Sue
Sue
--- In vantage@yahoogroups.com, Rob Bucek <rbucek@...> wrote:
> It certainly saves you from giving Epicor more money by doing the conversions for you...time aside, we made it through the whole conversion on a test run and while we were running our 1080 financial conversion (last step) a few hours into the process the server gave up the ghost..it was just too much for it I guess.. so back to square one on a new box..good times. We have a 44gb database and im estimating the process will be between that 24 and 36 hour time frame which is ok since we can cram it into a weekend based on that time.
> Sue - you should contact brad Johnson at Epicor directly, the destructions included aren't even close, and there are additional downloads (.p files etc) that you may or may not be aware of that need to replace or be added to the install. The conversion also seems sensitive to nonstandard file paths as well, use defaults in all instances.
> Rob Bucek
> Production Control Manager
> PH: (715) 284-5376 ext 311
> Mobile: (715)896-0590
> FAX: (715)284-4084
> [Description: cid:1.234354861@...]<http://www.dsmfg.com/>
> (Click the logo to view our site)<http://www.dsmfg.com/>
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of snielsen28
> Sent: Wednesday, April 25, 2012 2:48 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Upgrade from 8.03 406a to 9.05 help
> I signed the release, set things up and worked on the upgrade with the conversion tool. Thanks to this user group I made it all the way to the last conversion. Then I received a "cv/cvgl0013.p was not found" error that I couldn't get past. I logged a call with support. After waiting a couple of weeks and getting a couple of suggestions that didn't work, I gave up, installed 9.04 and took the long route. From what I read on on the user group, I don't know how much conversion time the tool saves.
> Sue
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Rob Bucek <rbucek@> wrote:
> > It is free..you just have to sign the standard 'its not your fault if we dork up our database with your fancy free tool' waiver.. and as far as converting from 8, the spin is you upgrade to 9.05.604 convert the data, then patch to current. Part of that process is running two schema changes that takes you from 8.03 to 9.04, then from 9.04 to 9.05
> > Rob Bucek
> > FAX: (715)284-4084
> > -----Original Message-----
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of John Driggers
> > Sent: Wednesday, April 25, 2012 9:13 AM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > Subject: Re: [Vantage] Re: Upgrade from 8.03 406a to 9.05 help
> > Sorry, sent that a bit too quick. I'm not sure if it's on the epicweb anywhere, but you should be able to get it from your CAM.
> > On Wed, Apr 25, 2012 at 10:11 AM, John Driggers <waffqle@> wrote:
> > > It's free.
> > > On Wed, Apr 25, 2012 at 10:00 AM, Gerry Loranger <
> > > gloranger@> wrote:
> > >> Hi Jose. What's the ballpark price on the tool?
> > >> Behalf Of Jose Gomez
> > >> Sent: April-25-12 9:57 AM
> > >> Gerry I don't know if he has it but there is a passthrough converter
> > >> tool that Epicor has.
> > >> *Jose C Gomez*
> > >> *Software Engineer*
> > >> *checkout my new blog <http://www.usdoingstuff.com> *
> > >> *T: 904.469.1524 mobile
> > >> E: jose@
> > >> http://www.josecgomez.com
> > >> <http://www.linkedin.com/in/josecgomez> <
> > >> http://www.facebook.com/josegomez>
> > >> <http://www.google.com/profiles/jose.gomez>
> > >> <http://www.twitter.com/joc85
> > >> <http://www.josecgomez.com/professional-resume/>
> > >> <http://www.josecgomez.com/feed/>
> > >> *Quis custodiet ipsos custodes?*
> > >> On Wed, Apr 25, 2012 at 9:55 AM, Gerry Loranger
> > >> <gloranger@>wrote:
> > >> > And you will need to convert your data on E 9.04 before converting
> > >> > it to E 9.05. You cannot go from 8 to 9.05 directly.
> > >> > Gerry Loranger
> > >> > Systems Administrator
> > >> > Preformed Line Products (Canada) Limited
> > >> > 1711 Bishop St
> > >> > Cambridge, On N1T 1N5
> > >> > Phone: 519-740-6666 Ext. 224
> > >> > Fax: 519-740-7917
> > >> > Visit our website at www.preformed.on.ca
> > >> > [Non-text portions of this message have been removed]
> > >> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > >> have already linked your email address to a yahoo id to enable
> > >> access. )
> > >> (1) To access the Files Section of our Yahoo!Group for Report Builder
> > >> and Crystal Reports and other 'goodies', please goto:
> > >> http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
> > >> (2) To search through old msg's goto:
> > >> http://groups.yahoo.com/group/vantage/messages
> > >> (3) To view links to Vendors that provide Vantage services goto:
> > >> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > > *John Driggers*
> > > *High End Dev, System Design, Profit Drinking*
> > > **:: 904.404.9233*
> > > *:: waffqle@*
> > > *:: NO FAXES*
> > *John Driggers*
> > **:: 904.404.9233*
> > *:: waffqle@*
> > *:: NO FAXES*
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
> > (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
