When shipping direct from a job, I have assumed the warehouse came from
the output warehouse/bin of the last operation's resource on the job.
Look in resource group maintenance. In our case, the parts on the order
& job are not in our part master, and the job is a single operation
make-to-order and it correctly chooses the warehouse/bin from that
resource (not from the plant default, which is a different warehouse).
Brian.
Of drewpatterson83
Sent: Friday, May 06, 2011 5:00 PM
Subject: [Vantage] Re: Epicor 9 - customer shipment entry ship from job
field question
Rob,
You are correct, thank you for the answer and quick reply.
In this case, though, I still have a problem. Any thoughts are
appreciated. I have two warehouses in the same plant. After blanking out
the warehouse record in the plant file, I was hoping the default
warehouse from the part master would populate in the shipment. It came
over blank. Of course it is demanding a warehouse, even though it is
shipping direct from a job. I get an error
I get the following error: "a valid WIP warehouse is reqd".
What is a WIP warehouse? Why do I need a warehouse if I ship direct from
a job?
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Rob
Bucek" <rbucek@...> wrote:
Behalf
Brian.
Of drewpatterson83
field question
Rob,
a job?
>primary
> I thought it was from the primary warehouse/bin as defined in the part
> entry. From there it should trace back to the partplant for the
> wharehouse, and plantwhse for the primary bin..[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Rob Bucek
> Production Control Manager
> PH: (715) 284-5376 ext 311
> Mobile: (715)896-0590
> FAX: (715)284-4084
> <http://www.dsmfg.com/>
> (Click the logo to view our site) <http://www.dsmfg.com/>
Behalf
> Of drewpatterson83[Non-text portions of this message have been removed]
> Sent: Thursday, May 05, 2011 11:22 AM
> Subject: [Vantage] Epicor 9 - customer shipment entry ship from job
> field question
> In the customer shipment entry, on the Line detail screen, there is a
> "from Mfg" warehouse.
> Does anyone know where the data in this field comes from, ie, it is
> filled in with a warehouse and bin, but I cant figure out where it is
> defaulting from.
> Thanks
