Epicor 9 Impossibly slow
Thanks Ned,
I just looked and we have one array of 4 drives for each VM.
We have been monitoring promon on Progress since yesterday and ti seems we
have an outrageous amount of record locks. Upwards for 14 Million at a time,
this drops rapidly and increases rapidly, but I am not certain we should be
getting that many.
Any thoughts?
For reference at any given time we have a max of 30 ppl in epicor.
Thanks!
Sincerely
Jose C Gomez
http://www.josecgomez.com
On Tue, Aug 10, 2010 at 10:09 AM, Ned <TechnoBabbly@...> wrote:
> What is the one storage device? SAN? Internal Drives? NAS?
> How many drives are in it? How many arrays are you running with those
> drives? How many VMs are using the storage device? What are the other VMs
> running?
> I am guessing you are running one giant array with all the VMs using the
> storage device and divvying up space based on the VM itself.
> This will kill your performance.
> Even with a VM, you will still want to separate out your drives physically
> for maximum performance out of the system.
> For the sake of example, if you have a storage device with say 14 drives in
> it.
> You could do a few different setups which would be better than the all in 1
> use of the storage device as I suspect you are currently using. Off the top
> of my head, 3 possible options would be:
> A- 6 Drives for your Vantage/Epicor VM and nothing else.
> B- 4-6 Drives for your Vantage/Epicor VM secondary Drive and nothing else,
> leave the OS on the other 8-10 drives as the other VMs
> C- Split out 2 drives and give them to my Vantage/Epicor OS drive, 6 drives
> to my Vantage/Epicor DB and Program Drive, and the remaining 6 to whatever
> other VMs you are running.
> Personally, I would run with option C, I think the value of a VM setup is
> always a better use of Processor power and RAM allocation, the bottleneck
> for Epicor/Vantage is always going to be disk access unless you go to one
> of
> those crazy expensive setups with the Fusion ioDrives. Dedicated drives
> will
> increase your performance, to use an old clich�, size is not important, you
> will get better performance out of 10 36GB drives in RAID 10 compared to 2
> 500GB drives in RAID 10.
> I am not saying you shouldn't get large sized drives, cuz who doesn't want
> more space, but concentrate on more disks versus disk size.
> Ned Cleary
> Technical Consultant
> alternative Technology Partners
> -----Original Message-----
> From: vantage@yahoogroups.com <vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com <vantage%40yahoogroups.com>] On Behalf Of
> Jose Gomez
> Sent: Tuesday, August 10, 2010 9:48 AM
> To: vantage@yahoogroups.com <vantage%40yahoogroups.com>
> Subject: Re: [Vantage] Epicor 9 Impossibly slow
> Thanks Chris,
> I will give those values a shot
> Its ESX on with one Storage Device usign Raid 10
> Sincerely
> Jose C Gomez
> On Tue, Aug 10, 2010 at 9:42 AM, Ned <TechnoBabbly@...<TechnoBabbly%40gmail.com>>
> wrote:
> > Well there are a few fixes you can do...
> > 1: Update to -Mm 4096, that will help you some, you could possibly go
> > higher, but I have never found a need for it, 4096 is pretty default.
> > 2: Update to -s 12000, that will help as well, also depends how much
> > RAM you have allocated, but that 50% jump can add a lot.
> > Also, you mention that you are running on a VM, depending how you have
> > your VMs setup, that right there is going to rip your performance right
> down.
> > What do you have for a VM setup? ESX? SAN? NAS? Internal Drives? How
> > are the drives broken up for use?
> > A lot of people don't realize the performance hit you will take when
> > you are using a VM and don't dedicate drives the same way you would a
> > physical machine, you can very easily create a bottleneck for the data
> > which can make even the "fastest" machines slower than a turtle stuck
> > in molasses.
> > From: vantage@yahoogroups.com <vantage%40yahoogroups.com> <vantage%
> 40yahoogroups.com>] On Behalf Of Jose
> > Gomez
> > Sent: Tuesday, August 10, 2010 8:20 AM
> > To: vantage@yahoogroups.com <vantage%40yahoogroups.com> <vantage%
> 40yahoogroups.com>
> > My PF File looks like this
> > -Mm 1024 -mmax 65534 -Bt 4096 -s 8000 -yy 1970 -stsh 31 -inp 32000
> > -tok
> > 4000
> > -TB 31 -TM 32 -D 500 -l 1000 -ttmarshal 5 -tmpbsize 8 -rereadnolock
> > -lkwtmo
> > 180
> > -T "C:\Program Files\Epicor Software\EpicorData"
> > -db "C:\Program Files\Epicor Software\Epicor904\db\mfgsys"
> > -cpinternal utf-8 -cpstream utf-8 -cprcodein utf-8 -cpcoll icu-uca
> > Sincerely
> > Jose C Gomez
> > On Tue, Aug 10, 2010 at 3:16 AM, Chris Thompson
> > <chriselectrix@... <chriselectrix%40ymail.com> <chriselectrix%
> 40ymail.com>>wrote:
> > > Hi Jose,
> > > Have you logged this as a call? If so what call number?
> > > The script we are using is ...
> > > @echo off
> > > set DLC=E:\epicor904\oe101c
> > > set PATH=%DLC%\BIN;%PATH%
> > > set LIB=%DLC%\LIB;%LIB%
> > > echo .
> > > echo .
> > > echo RESTARTING LOCAL DB/APPSERVERS...
> > > call asbman -name Epicor904ProcessServer -stop -port 20940 call
> > > asbman -name Epicor904TaskAgent -stop -port 20940 call asbman -name
> > > Epicor904 -stop -port 20940 call dbman -host localhost -database
> > > :TestStop
> > > ECHO Testing Lock File
> > > IF EXIST E:\epicor904\db\mfgsys.lk GOTO TestStop
> > > call dbman -host localhost -database Epicor904 -start -port 20940
> > > call asbman -name Epicor904 -start -port 20940 call asbman -name
> > > Epicor904TaskAgent -start -port 20940 call asbman -name
> > > Epicor904ProcessServer -start -port 20940
> > > Obviously you will have to change the paths to suit your server
> > > setup and you will probably have to change the port number on each
> occasion.
> > > Also, I cannot be held responsible for anything that goes wrong with
> > > your system when using this script. It is worthwhile testing it on
> > > Pilot or Test first.
> > > The check for the .lk is the bit that was missing from the answer
> > > books. It is a bit of a crude fix, but it does the job.
> > > We have found that the system is much more stable after deleting the
> > > old reports and temp files folders and defragging on a weekend.
> > > Let me know if you want those scripts too.
> > > Thanks,
> > > CHRIS
> > > ________________________________
> > > From: Jose Gomez <jose@... <jose%40josecgomez.com> <jose%
> > 40josecgomez.com>>
> > 40yahoogroups.com>
> > > Sent: Mon, 9 August, 2010 17:05:06
> > > Thank you Chris,
> > > we are running Progress and basically the whole app is running slow,
> > > takes time to open forms, time to search, time to save, searching
> > > for an SO can take minutes at times. Loading Invoices into ARGroup
> > > We've ran through the DB tunning guide today and tweaked all the
> > > values we could find, and hopefully this will fix some of our issues.
> > > But I find it absurd that it takes minutes to search for a sales
> > > Order, or to save a simple 10 line invoice.
> > > We've attempted calls with Epicor but they are ... well not very
> > > helpful, sadly although some of their people are really good, it
> > > seems like most of the gen pop support doesn't actually
> > > understand/know how to deal with this kind of issues.
> > > For what is worth we are running on w 2 quad cores with 12 GB of RAM.
> > > Which should be more than enough metal for the number of users we have.
> > > Thanks for your input and i'll let you know if we find anything else.
> > > Also can you share the start / stop script for the DB, apps etc, you
> > > mentioned that the one form epicor is flawed.
> > > Thanks again!
> > > Sincerely
> > > Jose C Gomez
> > > On Mon, Aug 9, 2010 at 11:48 AM, Chris Thompson
> 40ymail.com><chriselectrix%
> > 40ymail.com>
> > > >wrote:
> > > > HI Jose,
> > > > We have had a number of speed issues with Epicor 9.
> > > > If we leave the Apps and DB running for about a week, the system
> > > > will
> > > grind
> > > > to a
> > > > halt and we would have to stop the apps and db and sometimes
> > > > restart the server to fix the issue.
> > > > Epicor have accepted that this looks like a fault with Progress so
> > > > the
> > > call
> > > > has
> > > > been passed to them.
> > > > At present, we have a script in place to stop the apps then the
> > > > db, then restart the apps and the db - we run this every night out
> > > > of hours. If you are going to do this, please don't use the script
> > > > from Epicor's answer books as their
> > > is
> > > > a
> > > > fault with it. It doesn't wait for the DB to be stopped before
> > > > trying to restart the Apps which just ends up in a mess.
> > > > Secondly, on a weekend, we stop the apps, stop the db, clear out
> > > > any temp files and temp .xml data for reports, defrage all drives
> > > > on the server, start
> > > the
> > > > db,
> > > > start the apps.
> > > > So far, we have not had any 'major' slow downs where we have had
> > > > to kick people off the system during the working week.
> > > > We found that the reports folder (usually epicodata/reports) was
> > > > getting very full very fast. Some reports were are in excess of
> > > > 7GB in size (the xml
> > > for
> > > > them) so if you run these a few times a month, the folder size
> > > > increases rapidly.
> > > > One thing we noticed is that the archive option of 'Never' when
> > > > you run a report nearly always doesnt' work. 'Never' would appear
> > > > to either mean 30 days
> > > or
> > > > keep
> > > > forever - hence the reason why the reports folder was building up
> > > > in
> > > size.
> > > > What are you classing as slow and what are you comparing against?
> > > > Our speed issues have been associated with 'memory leaking' BAQs
> > > > and BAQs which crash on you causing the app server to get stuck in
> > > > a loop.
> > > > There are also other things which may speed things up such as
> > > > increasing number of App servers and tweaking settings in the
> > > > mfgsys.mfgsys file (but I
> > > would
> > > > get
> > > > advice from Epicor on these).
> > > > It is definately worth while logging a call for this issue as
> > > > something definately isn't right. Hopefully your call will be
> > > > linked with my call
> > > and
> > > > we
> > > > should get an answer quicker.
> > > > Are you progress or SQL?
> > > > Thanks,
> > > > CHRIS
> 40josecgomez.com>
> > > > <jose%
> > > 40josecgomez.com>>
> > > > To: Vantage <vantage@yahoogroups.com <vantage%40yahoogroups.com><vantage%
> 40yahoogroups.com>
> > > 40yahoogroups.com>>
> > > > Sent: Mon, 9 August, 2010 15:14:27
> > > > Subject: [Vantage] Epicor 9 Impossibly slow
> > > > I said las week that epicor 9 was running slower than normal, some
> > > > of you suggested various things but nothing seems to be helping.
> > > > Over the weekend, we re-indexed the DB, did a dump and load,
> > > > truncated
> > > the
> > > > bi and god knows what else. It seems to be running awful still
> > > > this morning after all that.
> > > > Does anyone have any troubleshooting / tracing / fixing ideas that
> > > > may
> > > help
> > > > us determine where the problem is?
> > > > Thank you in advance!
> > > > Sincerely
> > > > Jose C Gomez
> > > > [Non-text portions of this message have been removed]
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> > > must have
> > > already linked your email address to a yahoo id to enable access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> > > Builder and Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
We see the same spike in locking activity. 9.04.504B.
On Aug 10, 2010 10:26 AM, "Jose Gomez" <jose@...> wrote:
Thanks Ned,
getting that many.
Any thoughts?
Thanks!
Sincerely
Jose C Gomez
> What is the one storage...
> vantage@yahoogroups.com <vant...
> Subject: Re: [Vantage] Epicor 9 Impossib...
> Thanks Chris,
> Its ESX on with one Storage Device usign Raid ...
40gmail.com>>
> > 1: Update to -Mm 4096, that ...
> 40yahoogroups.com> [mailto...
> 40yahoogroups.com>] On Behalf Of...
> 40yahoogroups.com>
> > Subje...
> 40ymail.com>>wrote:
> > > Hi Jose,
> > > Have you logged this as a call? I...
Thanks Mark at least I know that's not the problem
Sincerely
Jose C Gomez
> On Aug 10, 2010 10:26 AM, "Jose Gomez" <jose@...<jose%40josecgomez.com>>
> wrote:
> Thanks Ned,
> time,
> getting that many.
> Any thoughts?
> Thanks!
> Sincerely
> Jose C Gomez
> On Tue, Aug 10, 2010 at 10:09 AM, Ned <TechnoBabbly@...<TechnoBabbly%40gmail.com>>
> > vantage@yahoogroups.com <vantage%40yahoogroups.com> <vant...
> 40yahoogroups.com>
> > Thanks Chris,
> <TechnoBabbly%
> 40gmail.com>>
> > 40yahoogroups.com>
> > > Subje...
> > 40ymail.com>>wrote:
> > > > Hi Jose,
Or we both have the same problem!
Sincerely
Jose C Gomez
> We see the same ...
40josecgomez.com>>
> wrote:
> Thanks Ned,
> We hav...
> 40yahoogroups.com>
> > Thanks Chris,
> > I wil...
[Non-text portions of this message...
http://groups.yahoo.com/group/vantage/join
(Yahoo! ID required)
As a new Epicor customer, we have 8 months experience with v9.04.5.5B (SQL) in implementation as we prepare for launch. We are at or above the recommended RAID10 hardware configs but continue to encounter poor to average performance and response times. This, with 8 users and a relatively small # of test transactions and data.
We see random MfgSys.exe crash on client PC's (4gb+ RAM) as a daily event. We cannot replicate the scenarios nor find any advice - other than something we have to live with. Our choice of DB is MS SQL, there are still legacy Progress code throughout.
We will continue to seek assistance from Epicor on performance tuning, but essentially we are putting lipstick on a pig. Hopefully there are upcoming performance patches, but new v9 customers beware - if it smells like a pig, it is probably a pig.
> Sincerely
> Jose C Gomez
> > We see the same ...
> 40josecgomez.com>>
> > wrote:
> > Thanks Ned,
> > We hav...
> > 40yahoogroups.com>
> > > Thanks Chris,
> > > I wil...
THat's what we think too!
Sincerely
Jose C Gomez
> --- In vantage@yahoogroups.com <vantage%40yahoogroups.com>, Mark Wonsil
> > Sincerely
> > Jose C Gomez
> > > We see the same ...
> > 40josecgomez.com>>
> > > wrote:
> > > Thanks Ned,
> > > We hav...
> > > 40yahoogroups.com>
> > > > Thanks Chris,
> > > > I wil...
