Epicor 9 - Report Parameters on Standard Reports
Do you know of any way that a simple tick box can be added to the print screen one for fax and one for email? Then the user at print time can decide which way they want to send the document?
It seems starnge that you can edit the print dialog for custom reports but not for standard ones.
Sent: Monday, 22 June, 2009 17:20:52
Subject: [Vantage] Re: Epicor 9 - Report Parameters on Standard Reports
It would be my guess that this is a case where the default 'Dynamic' routing would need to be changed. I believe it is possible to base routing of documents based upon criteria you specify. Thus document A to customer XYZ is routed by Fax only. Document A to customer DEF is routed to email only. Document A to customer HIJ is routed to printer and snail mailed...... .
--- In vantage@yahoogroups .com, Chris Thompson <chriselectrix@ ...> wrote:
> Hi Brian
> That's what you would think, but our customers are fussy.
> We need their fax and email on our paper work, but if they want it to be sent to fax they have to have it sent to fax or there will be complaints.
> Cheers,
> CHRIS
> ____________ _________ _________ __
> From: Brian W. Spolarich <bspolarich@ ...>
> To: vantage@yahoogroups .com
> Sent: Monday, 22 June, 2009 14:38:38
> Subject: RE: [Vantage] Epicor 9 - Report Parameters on Standard Reports
> Chris, so the real problem here is that if there's a fax and an e-mail address on the SO, then Altec sends to both?
> Why not just set a conditional suppression formula on the fax# that effectively creates the rule "if there's an e-mail and a fax# defined for the customer, only print the e-mail address on the SO acknowledgement" ?
> This would solve your problem, no? Presumably you want to e-mail before faxing if you can since its free for you.
> -bws
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
> Â Â Â Â bspolarich@advanced photonix. com ~ 734-864-5618 ~ www.advancedphotoni x.com
> -----Original Message-----
> From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf Of Chris Thompson
> Sent: Monday, June 22, 2009 9:33 AM
> Subject: [Vantage] Epicor 9 - Report Parameters on Standard Reports
> Hi,
> I have a sales order acknowledgement report which can be sent to the customer in three ways:
> Email
> Fax
> Printed then Snail Mail
> We are using Altec to print through which works very well, however, if you have a SO Acknowledgement with a Fax and Email address on, Altec will send to both.
> The obvious way around this is to have 3 reports styles linked to 3 Crystal reports - one for fax, email and print, so the user can select which one they require.
> The downside to this is if you make a change to one of the crystal reports, you have to make a change to the others which is time consuming and if you forget and lead to things going wrong.
> So then I thought about using report parameters (like when you are printing Travelers and you have the option to print barcodes etc). The problem is, I don't know where to begin.
> I know how to supress information in Crystal once it is there, but I don't know how to get it there.
> I think I will have to customise the print screen for SO Ack's but I don't know what to do.
> Any help would be appreciated.
> Cheers,
> CHRIS THOMPSON
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups. yahoo.com/ group/vantage/ files/.
> (2) To search through old msg's goto: http://groups. yahoo.com/ group/vantage/ messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
Hi,
Email
Fax
Cheers,
CHRIS THOMPSON
Why not just set a conditional suppression formula on the fax# that effectively creates the rule "if there's an e-mail and a fax# defined for the customer, only print the e-mail address on the SO acknowledgement"?
-bws
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Chris Thompson
Hi,
Email
Fax
Cheers,
CHRIS THOMPSON
Hi Brian
Cheers,
CHRIS
-bws
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of Chris Thompson
Hi,
Email
Fax
Cheers,
CHRIS THOMPSON
Hmm. Well, what about putting another field on the form that you tell Altec about that is the actual field that APM uses for delivery? Inelegant duplication I know...
Sent: Monday, June 22, 2009 11:18 AM
Subject: Re: [Vantage] Epicor 9 - Report Parameters on Standard Reports
Hi Brian
Cheers,
CHRIS
-bws
Hi,
Email
Fax
Cheers,
CHRIS THOMPSON
It would be my guess that this is a case where the default 'Dynamic' routing would need to be changed. I believe it is possible to base routing of documents based upon criteria you specify. Thus document A to customer XYZ is routed by Fax only. Document A to customer DEF is routed to email only. Document A to customer HIJ is routed to printer and snail mailed.......
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> Hi Brian
> Cheers,
> CHRIS
> From: Brian W. Spolarich <bspolarich@...>
> -bws
> Hi,
> Email
> Fax
> Cheers,
> CHRIS THOMPSON
