That's the same route I took, we're on ver 6.10, one drawback is each user's 'Launch Script' has to have the 'ODBC' info included, sometimes they use old 'icons' and have trouble printing Quotes.
--- On Tue, 11/4/08, Kersten MacLennan <kmaclennan@...> wrote:
Subject: RE: [Vantage] Re: Report frustrations
Date: Tuesday, November 4, 2008, 3:43 PM
I have modified the report and added an ODBC connection to retrieve the
email address.
Kersten MacLennan
IT/ERP Analyst
Semrock
A Unit of IDEX Corporation
3625 Buffalo Road, Suite 6
Rochester, New York 14624
585-594-7009
585-594-7095 fax
kmaclennan@semrock. com
The Standard in Optical Filters for Biotech & Analytical Instrumentation
Hundreds of Thousands of Ion Beam Sputtered filters delivered -
extensive inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of andrew.tapper
Sent: Tuesday, November 04, 2008 10:44 AM
To: vantage@yahoogroups .com
Subject: [Vantage] Re: Report frustrations
Did you ever find a resolution/work around for this. I am trying to
do the same thing.
What was Epicor thinking in not bringing the Primary Contact's email
onto the Quote form??!!??
Andrew
--- In vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ,
"hoomail4me" <hoomail4me@ ...> wrote:
> Yes, we are on 8.03.404b.
> I can select any defined customer contact I want for the quote
> (People\Contacts) and the phone and fax numbers for this contact
will
> print on the quote but the email address of the "contact" will not.
> The email address for the quote will pull from the customer detail
screen.
> I am trying to use APM to automate the delivery of the quote but the
> person initiating the process will "assume" that the email address
of
> the "quote contact" will be the recipient.
> In most situations, we send quotes to various customer contacts and
> cannot use the only email address assigned on the customer detail
screen.
> At the very least, it should be consistent. The phone, fax, and
> address should ALL pull from either the contact OR customer detail.
"Ken Williams" <ken@> wrote:
> > I'm a little confused, are you on 8.0? On the quote under
the "People"
> > tab there is a "Contacts" tab. We use this tab quite regularly to
> > select specific contacts for a quote.
> > Ken
