Epicor and Citrix
Are there any companies out there using Citrix to run their Epicor 9 applications? We are managed and hosted through Epicor's Managed Services. We are running Epicor 9.05.606 64-Bit SQL. We have a physical Citrix server running Windows Server 2008 R2 Enterprise with 64GB RAM, and 4 cores (2.00GHz). We have plenty of horse power on this server and yet Epicor Managed Services is recommending that we run no more than 30-35 users. The server processor is barely moving at all and the memory utilization is sitting at 26% with 42 users.
Does anyone have any recommendations on the number of users that can run on a physical Citrix server with these kinds of specs?
The issue we are currently having is that users from all locations are intermittently receiving the errors below when trying to launch the published Epicor 9 application. They can log into the Citrix Program Neighborhood Agent without errors, but then cannot access the applications, but if they try to launch the same Epicor 9 application 10 minutes or an hour later they can get in without any problems. Has anyone seen these errors before?
[cid:image001.png@01CC836C.70EA9470]
[cid:image002.png@01CC836C.70EA9470]
Thank you,
Lauren Hellings
Business Analyst
Office: 281-207-4613
Cell: 832-472-1736
----------Legal Disclaimer----------
The information contained in this message may be privileged and confidential, and is intended solely for the use of the named addressee. No other person is authorized to access, copy or re-use this message (or any information contained herein). If you are not the intended recipient, please notify us immediately by replying to this message and delete it from your computer.
