Epicor Email Log
The log file is defined in System Mgt. > BPM > GO - Action process when you started the BPM processing. You can see the default there.
it references the local drive on the server where Epicor is installed. Mine is E:/EpicorData/BPMAction.log
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Anon
Sent: Thursday, September 27, 2012 10:14 AM
Subject: [Vantage] Epicor Email Log
I have a BPM that I want to have send an Email off. I have used this before, but am having trouble with one in particular. I don't see the email hit my email server log, so where in Epicor might I see what is going on with it?
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at (727) 578-6258 and immediately delete the communication.
Try looking in your server log (in Epicor905/server/logs). And if you
use global alert emails, those are in another log file, called umm...
GlobalAlerts.log?
A tip from when I struggled when some intermittent email problems. In
your BPM, add this line just before you send each email:
Message "sending xxx email to: " + vTo etc ...
That message will appear in your server log, just before each possible
error message.
Brian.
Of Anon
going on with it?
