EpiNumeric Not Displaying Well Until Click
Classic here, I know…
In any case, anyone have any ideas on how to get this decimal to display correctly? When I open the form it isn’t aligned well until I click into the box and then it displays the whole number. Any ideas?
F46B3154-F61D-48DD-A1AF-E0B2758BE323
Check your leading digits in the field properties. It is probably expecting a gigantic number and formatting based on that.
It’s a formatting issue somewhere in the chain. Either in property of the data, or the property of the control. Look through all of them and see if any of them aren’t set, or are set incorrectly. Start showing some screen shots and we can probably point out where to look. I’ve seen that before and have been able to fix it.
Also, I notice your “scrap” field is changing when you click in there. So something else is going on too.
edit: actually, a bunch of fields. What’s going on?
Haha I didn’t even notice that. Yeah that’s weird.
Haha, yeah I cut the clip so now it looks weird. I clicked on something in the back ground, etc. I meant to just click the field and show it re-formatting/shifting.
Thanks for offering to help will post soon.
