Error Message when editting Engineering BOM or Operations
I'd say they have a problem. We are running 8.00.10b and getting this
same error when entering Labor against any Job which has been modified
through Jpb Entry. The system hangs/crashes while saving data,
eventually this error pops up. The problem is, the Save process can
take up to 10-12 min, if it ever saves, or you go through several
crashes and restarts before it finally produces the error and allows
the refresh. Our complaint has been kicked up to Development as I
understand.....
Mike
--- In vantage@yahoogroups.com, "bnazmi38" <bahramn@...> wrote:
> Is anyone familiar with this error message that pops up each time a
> change is made to an operation or Materials in the MOM in
Engineering
> workbench? "Record has been modified by another user and couldn't be
> updated. Please press the Refresh button and re-enter your changes"
> Once it is refreshed you can then proceed and re-enter the change
with
> no problem.
> Is this a bug in the system? Is there a way to avoid this?
> Bahram N.
change is made to an operation or Materials in the MOM in Engineering
Once it is refreshed you can then proceed and re-enter the change with
no problem.
Bahram N.
