What is the fastest way to retrieve the value of a UD field on the OrderHed_UD table in C# using Epicor version 10.1.600.30?
Bit of an odd question, but I’d ask if you are using a BPM or something else first?
I am using a form customization. I know GetList is very fast but it does not return UD fields. I usually fall to GetRows as my next option which is slower. GetByID is really slow. Using a BAQ to retireve the data is slow. I was wondering if there was something else to try that is faster than GetRows.
BOReader perhaps.
+1 for BO reader
BO Reader, BAQDataView, FKV, couple different options depending on your end goal use of said UD Field.
BOReader seems to be twice as fast as GetRows. Thanks! Someone marked Jose as providing the solution. I unchecked it. Then checked it back! You can’t stop me.
Nice. I’d like to optimize my customizations to use BOReader. Original author used lots of GetByID’s. I was going to change those to use specific BAQs (which I thought what optimal (returning fewer rows) but now that i’m seeing this is the optimal solution. Thanks guys!
