Forms Modification [6.1.533]
Brian,
Articles 1189MPS & 2344MPS pointed me in the direction for fixing this
problem. Solution was to change the ODBC server name in the vantage.vtg
file. Our original setup had the system DSN server name as vantage and
the vantage.vtg file ODBC name as progress91d.
Chris
_____
Of Brian Stenglein
Sent: Friday, August 18, 2006 6:03 AM
Subject: [Vantage] Re: Forms Modification [6.1.533]
Keep in mind that you can search ePortal and maybe find the document.
Brian
"Chris Crosta" <chris@...> wrote:
> Brian,
> Thanks for the information, I have a call into Epicor support but I
> don't think it is very high on their priority list.
> I tried inserting a subreport into the report footer but get
error "599"
> when it tries to print the last page.
> _____
Behalf
> Of Brian Stenglein
> Sent: Thursday, August 17, 2006 1:05 PM
> I'm not familiar with this particular form, but in general you need
> to add the table in a subreport via ODBC. Support should have a
> document detailing the steps.
> HTH,
> Brian Stenglein
> "Chris Crosta" <chris@> wrote:
> > How do I go about adding fields to a standard form that are not
> > contained in the dbf files and still maintain running it from the
> > vantage menu.
> > I am trying to add the Due Date and Part Number fields from the
> JobHead
> > table to the Job Pick List form.
> > Thank you,
> > Chris Crosta
vantage menu.
I am trying to add the Due Date and Part Number fields from the JobHead
Thank you,
Chris Crosta
HTH,
Brian Stenglein
> vantage menu.
JobHead
> Thank you,
> Chris Crosta
Brian,
I tried inserting a subreport into the report footer but get error "599"
_____
Of Brian Stenglein
HTH,
Brian Stenglein
> vantage menu.
JobHead
> Thank you,
> Chris Crosta
You have to make sure the ODBC connection is installed on the
computer where you are trying to run the report. Make sure to run
the outjoin file.reg on the computer also.
Then, you also have to remove the comments from the Vantage
connection file(Right click on the Vantage icon, and click edit) Then
remove the comments on the last 4 lines where it has the ODBC
parameters. I pasted our file below. (You may want to make 2
versions of this file because if there are any computers using
Vantage that do not have ODBC installed, I do not think they will
connect if the ODBC parameters are not commented out.)
Once you do that, the report should print without the 599 error.
Joe Giannola
Plitek, LLC
[MFG Startup]
Executable=W:\progress\bin\prowin32.exe
Database=T:\mfgsys61\db\MFGSYS
IniFile=T:\mfgsys61\mfgsys.ini
ParameterFile=T:\mfgsys61\db\mfgsys.pf
ConnectOptions=-N TCP -H vantage -S 6100 -ld MFGSYS
TempDirectory=C:\Epicor\MfgWrk61
StartupProcedure=mainmenu.w
OtherParameters=-rand 2 -q -basekey ini
mfgsys=VN
mfglanguage=enu
mfgtranslator=yes
unicode=true
*******---------> remove the ";" for these 4 lines <---------****
;MFGODBCpasswd=sysprogress
;MFGODBCUser=sysprogress
;MFGODBCDbse=mfgsys
;MFGODBCServer=Progress91D
> Brian,
error "599"
> _____
Behalf
> Of Brian Stenglein
> HTH,
> Brian Stenglein
> > vantage menu.
> JobHead
> > Thank you,
> > Chris Crosta
Brian
> Brian,
error "599"
> _____
Behalf
> Of Brian Stenglein
> HTH,
> Brian Stenglein
> > vantage menu.
> JobHead
> > Thank you,
> > Chris Crosta
