Function and UD tablesets - trouble updating
Any idea why this works:
// update/validate test results
var context = (Erp.ErpContext)Ice.Services.ContextFactory.CreateContext();
var erpContext = new Erp.Internal.Lib.CCredChk(context); // used this library/assembly only for erpContext
Ice.Contracts.UD03SvcContract ud03Entry = Ice.Assemblies.ServiceRenderer.GetService<Ice.Contracts.UD03SvcContract>(erpContext.Db, true);
using(var txscope = IceDataContext.CreateDefaultTransactionScope())        //Start Transaction
  foreach(var ud03_xRow in (from row in **erpContext.Db.UD03**
  where row.Company == Session.CompanyID &&
  row.Status_c == String.Empty
  select row))
But this generates an error on syntax check?:
**var dsUD03 = new Ice.Tablesets.UD03Tableset();**
  foreach(var ud03_xRow in (from row in **dsUD03**
  select row))
CS1936 Could not find an implementation of the query pattern for source type ‘UD03Tableset’. ‘Where’ not found.
On possibly a related note, this code returns a “sorry something went wrong” message unless I comment out the assignment statment - ud03_xRow.Status_c = “Validated”; - or comment out the validate.
  foreach(var ud03_xRow in (from row in erpContext.Db.UD03
  select row))
    //ud03_xRow.Status_c = "Validated";
    erpContext.Db.Validate();
  //erpContext.Db.Validate();
  txscope.Complete();                            //Close Transaction
Assemblies and services as such:
I’d surely appreciate some direction.
Joe
Dang. One problem solved.
“Validated” exceeded the length of my status field (6).
I’d still like to figure out the issue of not being able to read through the UD03 tableset.
Joe
