There were previous postings (see bellow) explaining how to block
external addresses. I have Exchange 2000 and am have difficulty
following the instructions bellow which are for Exchange 5.5. Does
anyone know how to do this in Exchange 2000? I am having trouble
creating a "Recipients Container". It seems to me that the only way you
can block and address is if it is in your exchange list. Do I just make
an address and then hide it then block it? Any help would be greatly
appreciated.
Juliet
In September of 2000 I believe Todd Anderson contributed these
instructions.
MS-Exchange: To block emails from a specific person to a specific
person.
Phase 1: Initial Setup - Create a "System" folder to hold all external
addresses to be blocked.
* Click on Company folder at the root level. This is located
underneath the main company folder and contains the "RECIPIENTS" folder.
* From menu bar click on "FILE / NEW OTHER - RECIPIENTS CONTAINER"
* Enter the folder name as XXINT and the directory as XXINT and click
on OK
Note: These could be in the "Standard" recipients folder but it makes it
easier to find them if you put them in a separate folder.
Phase 2: Add blocks as required.
Step 1: Setup the "External" internet address and block traffic from the
internal email address.
* Click on XXINT folder to add a new system level recipient.
* From menu bar click on "FILE / NEW CUSTOM RECIPIENT"
* Specify address type is "INTERNET" and click OK.
* Enter the external email address you want to block. Then highlight
it, press Control-C, and then click OK.
* Use Control-V to paste the same email address into the "DISPLAY" and
"ALIAS" fields and type the person's name of the internal address we are
blocking into the "TITLE" field for documentation.
* Click on the "DELIVERY RESTRICTIONS" tab.
* Under "REJECT MESSAGES FROM" click on LIST and then click on MODIFY.
* Add the internal email name to the "REJECT MESSAGES FROM" column and
click ok
* Click APPLY and OK to complete this transaction.
Step 2: Update the "Internal" mail address to block traffic from the
outside
internet email address.
* Click on the "RECIPIENTS" file to access the standard company email
list.
* Double click on the internal mailbox/account you want to lock down.
* Change the "SHOW NAMES FROM" dialog box to point to the "XXINT -
RECIPIENTS" folder.
* Add the external address to the "RESTRICT MESSAGES FROM" column and
click OK.
Note: The only "External" email address that will show in the XXINT
folder
are the new ones you have just entered. Once you complete Step 3 they
will
be hidden from this step.
Step 3: Hide the "External" internet email address so that it does not
show
to Outlook users as a valid email address.
* Click on the "XXINT" folder to access the system recipients.
* Double click on the external mailbox/account you created in STEP-1.
* Click on the "ADVANCED" tab.
* Click ON "HIDE FROM ADDRESS BOOK"
Note: If you want to see the hidden email addresses in the XXINT folder
click on the XXINT folder and, then from the menu bar, click on "VIEW /
HIDDEN RECIPIENTS"
Note: If you want to allow traffic between the two people but want to
block
ANY attachments ---- do not reject msg's either way --- just set the max
msg
size to 10K on the outside address and / or the inside address. You can
limit incoming or outgoing or both.
Sent: Tuesday, September 12, 2000 1:09 PM
To: Vantage Egroup (E-mail)
Subject: [Vantage] Off topic: Exchange 5.5
Hey group is there a way to not allow certain file types to be forwarded
to a mailbox on Exchange 5.5? We are getting bombarded with large file
attachments, mostly mpg's, and need to stop it. Any suggestions besides
beating users on a regular basis?
Todd
(Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password,
the link above will work the next time you try it.)
appreciated.
Juliet
instructions.
person.
on OK
click ok
outside
list.
RECIPIENTS" folder.
click OK.
folder
will
show
HIDDEN RECIPIENTS"
block
msg
Todd
