Good afternoon,
I have another interesting request. What we are trying to do is somehow print inspection results to a report.
We have a laboratory facility that performs internal calibrations and we were trying to use Inspection Plans and Specifications to achieve this. The interesting part is we are able to get the data and input our test attributes etc. but in Inspection Result, the bottom Panel card, Inspection Sample Results, lists all the data that we input during the Inspection Plan, but when I have been inspecting the data, it seems it breaks it out to multiple tables (InspResults, InspResultsNum, InspResultsChar, InspResultsDate, etc) which seems to somehow compile the data from different tables to display it there. Is there a way to piggyback off of what the system is doing and dump it into a report or create a BAQ that is robust enough to be used for multiple Calibrations? Or do you think I should createa BAQ/BAQ Report for each Calibration we are creating?
Thank you guys for your all the help
