Use the comments on the header of the sales order....they will print automatically on the invoice.
Create text that can be "dropped in" the comments section. This is a little hard to explain in an email so bear with me. You can create a variety of "texts" (keep them in a folder that everyone has access to), then right click on the comments section and "insert file". If you look at the bottom of the comments section there is a duplicate button that will copy this over to the invoice screen.
I hope that made sense....
Or keep them in the customer file and copy paste to the sales order.
M. Manasa Reddy
manasa@...<mailto:manasa@...>
630.806.2000 x1515
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jfmartin67
Sent: Thursday, April 19, 2012 11:05 AM
Subject: [Vantage] getting billing info from sales order/customer info to be picked up in invoicing
we're trying to figure out the best way to communicate billing info (i.e. misc charges or waiving misc charges) in either the sales order or customer info to be picked up in invoicing.
the challenge we have is that we create invoices off of shipments.
we were hoping to use comments section in the customer records and comments section in the sales order header so that the a/r person could use that information to charge miscellaneous charges (or waive the usual misc charges) for customers, but the comments don't seem to work easily/can't see them in the invoice entry screen.
how do people get that information to the a/r group through epicor?
Total Control Panel
Login<https://asp.reflexion.net/login?domain=weldcoa.com>
To: manasa@...<https://asp.reflexion.net/address-properties?aID=516126014&domain=weldcoa.com>
From: sentto-20369-109478-1334851521-manasa=weldcoa.com@...<https://asp.reflexion.net/address-properties?aID=635087659&domain=weldcoa.com>
Message Score: 20
High (60): Pass
My Spam Blocking Level: Low
Medium (75): Pass
Low (90): Pass
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-address=1&rID=516126014&aID=635087659&domain=weldcoa.com> this sender
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-domain=1&rID=516126014&aID=635087659&domain=weldcoa.com> returns.groups.yahoo.com
This message was delivered because the content filter score did not exceed your filter level.
M. Manasa Reddy
630.806.2000 x1515
Total Control Panel
Message Score: 20
High (60): Pass
Medium (75): Pass
Low (90): Pass
