Getting the Part BinNum on a PackSlip
Hi
You need to link the odbc shipdtl table to the main form via a
subreport, linking to the company, packnum and packline fields. The
insert the subeport into the line detail
Gary Parfrey
Of Steve Bedilion
Sent: 08 June 2006 13:04
Subject: [Vantage] Re: Getting the Part BinNum on a PackSlip
I'm looking for the same...did you figure it out?
"Erik Smalley" <esmalley@...> wrote:
> Is there any way to get the BinNum from where a part is being pulled
> on the Crystal PackSlip form?...this is using Vantage 6.0. The field
> is in the ShipDtl table but not available in the temp tables for the
> forms.
> Thanks!
> - Erik
This e-mail is for the use of the intended recipient(s) only. If you have received this e-mail in error, please notify the sender immediately and then delete it. If you are not the intended recipient, you must not use, disclose or distribute this e-mail without the author's prior permission. We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses.
forms.
Thanks!
- Erik
> forms.
> Thanks!
> - Erik
You need to modify the Crystal form to use an ODBC connection to retrieve
the actual ShipDtl record from the database rather than using the DBF
version.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Steve Bedilion
> forms.
> Thanks!
> - Erik
