Grabbing the .p files from export utility
I figured out a way to get the .p files created by export utility. I
created a new .vtg and .ini file with the local work directory pointing
to our Novell server. Once the report is run (you can even abort it),
you go to the work dir on the Novell server, and do a "salvage", and you
see both the .p and the .r files which were created for that report.
Britt Moelling
M&M Manufacturing Co.
