Help For A BPM Newbie
Yes, I think you might be right Stephen...
I am going to have a play around with this and let you know how I get
on... I will either get it to work, or it will drive be around the
bend...! ;o)
You mention using a BAM to print out labels automatically. This would
be very useful to do in its own right but again, I haven't done this
before. I may be back to you for some additional help if I get stuck
on this one...!
What is bar tender...? I am not familiar with this...?
Nick
--- In vantage@yahoogroups.com, "Stephen Edginton" <stephene@...>
wrote:
> Hi Nick,
> Yes it is possible but for a first BPM it is one of
the
> more complex ones to try...
> You may find with your service connect experience that the best
option
> is to
> Use the BPM to fire off a BPM workflow that does the required
actions
> within vantage (issuing to the job).
> You can do the checking of the material queue from the conditional
part
> of the bpm.
> To print, a tag you can use the BAM subsystem with auto print or
write
> out directly for bar tender to
> Pick up and process.
> Regards,
> Stephen
Behalf
> Of nmtaylor1969
> Sent: 20 October 2008 19:02
> To: vantage@yahoogroups.com
> Subject: [Vantage] Help For A BPM Newbie
> Can anyone tell me if A BPM can be used for the following
application
> please...?
> When I receive parts through receipt entry, I would like to look if
an
> entry for the part exists in the material queue, and if so, issue
it to
> the job, update the material queue, and print a tracking label.
> Naturally if multiple entries exist in the material queue, then
they
> should be fulfilled until the incoming inventory is exhausted.
> I haven't used BPM's yet, and I need to know if this is feasible
before
> I attempt to write one...
> Any advice would be most welcome... I am trying to retain the
> flexability of an inventory part yet treat them as a buy-direct
part on
> receipt. Not sure if that makes sense, but it works for us!
> Thanks,
> Nick Taylor
Can anyone tell me if A BPM can be used for the following application
please...?
When I receive parts through receipt entry, I would like to look if an
entry for the part exists in the material queue, and if so, issue it to
Naturally if multiple entries exist in the material queue, then they
I haven't used BPM's yet, and I need to know if this is feasible before
flexability of an inventory part yet treat them as a buy-direct part on
Nick Taylor
Hi Nick,
Yes it is possible but for a first BPM it is one of the
You may find with your service connect experience that the best option
is to
Use the BPM to fire off a BPM workflow that does the required actions
You can do the checking of the material queue from the conditional part
of the bpm.
To print, a tag you can use the BAM subsystem with auto print or write
Regards,
Stephen
Of nmtaylor1969
please...?
Nick Taylor
