Jose,
Thanks for another great tip. I was able to use the Message statement to
debug my ABL.
Mike
Jose Gomez
Sent: Thursday, June 21, 2012 9:43 AM
Subject: Re: [Vantage] Help with ABL Code Please.
On the for what is Worth Category if you type anywhere in your ABL
Message 'YOUR MESSAGE HERE' + STRING(YourTable.Var).
This will be writter to \\Epicor\Server\Logs\YourServer.Log
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
debug my ABL.
Mike
Jose Gomez
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Jun 21, 2012 at 9:36 AM, Rob Bucek <rbucek@...> wrote:
> Typically jobhead.partnum would contain the 'end item',
> jobasmbl.partnum would be each make direct assembly.
> Rob Bucek
> Production Control Manager
> PH: (715) 284-5376 ext 311
> Mobile: (715)896-0590
> FAX: (715)284-4084
> [Description: cid:1.234354861@...]<
> http://www.dsmfg.com/>
> (Click the logo to view our site)<http://www.dsmfg.com/>
> Behalf Of Mike Numbers
> Sent: Thursday, June 21, 2012 8:30 AM
> Subject: RE: [Vantage] Help with ABL Code Please.
> You're right. JobOper Partnum does not match JobHead. Thanks for the
> tip on Jose's blog on debugging ABL code.
> Guess I need to figure out new logic to find all jobs for a partnum.
> Thanks again.
> Mike
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
> Of
> Ted Koch
> Sent: Wednesday, June 20, 2012 5:16 PM
> I could be wrong but I think you're only going to get a part number in
> JobOper.PartNum if it is a subcontract operation, and depending how
> you are structuring your jobs I dont know if your jobhead.partnum will
> equal joboper.partnum.
> My guess is its not doing anything because nothing matches the
> criteria in your second for each loop. Did you create a BPM and verify
> that a criteria like this returns anything? You can also debug your
> ABL code. Here is an example from Jose's blog
> http://www.usdoingstuff.com/2011/06/08/writing-to-a-file-from-progress
> -abl4g
> l/ (thanks Jose).
> Hope that helps,
> -Ted
> From: mike.numbers <mnumbers@...<mailto:mnumbers%40cignys.com>
> <mailto:mnumbers%40cignys.com> >
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:
> Sent: Wednesday, June 20, 2012 2:20 PM
> Subject: [Vantage] Help with ABL Code Please.
> This is my first time with ABL code with any complexity. The code
> validates but my results are not there. I have this code attached
> PreProcessing Method Directive with Labor.Update. I know it runs
> because I put an informational action after this action and it
> appears. The code is supposed to get the part number from the Jobhead,
> then read all completed operations for this part and operation and
> then calculate a new estprodhr and estsethr.
> I save the previous values in partopr.number01 and number02.
> Epicor 9.04.507a
> Any help in showing me where I screwed up would be appreciated.
> Below is my code.
> TIA
> Mike
> define variable AveSet LIKE PartOpr.EstSetHours.
> define variable AveProd LIKE PartOpr.EstProdHours.
> for each JobHead where JobHead.JobNum = ttLaborDtl.JobNum no-lock.
> if available JobHead then do:
> /* need JobHead to get Partnum */
> for each JobOper where JobOper.PartNum = JobHead.PartNum and
> JobOper.AssemblySeq = ttLaborDtl.AssemblySeq and JobOper.OprSeq =
> ttLaborDtl.OprSeq and JobOper.OpComplete = True no-lock.
> /* accumulate totals for each completed job for this operation */
> ACCUMULATE JobOper.QtyCompleted (SUB-TOTAL).
> Accumulate JobOper.ActProdHours (SUB-TOTAL).
> Accumulate JobOper.ActSetupHours (SUB-TOTAL COUNT).
> end.
> /* calculate averages */
> AveProd = (Accum Sub-Total JobOper.ActProdHours) / (Accum Sub-Total
> JobOper.QtyCompleted).
> AveSet = (Accum Sub-Total JobOper.ActSetupHours) / (Accum Count
> JobOper.ActSetupHours).
> /* get PartOpr to update new values */ find PartOpr WHERE
> PartOpr.PartNum = JobHead.PartNum and PartOpr.OprSeq =
> ttLaborDtl.OprSeq and PartOpr.RevisionNum = JobHead.RevisionNum.
> Assign
> /* save last value*/
> PartOpr.Number01 = PartOpr.EstProdHours
> PartOpr.Number02 = PartOpr.EstSetHours
> /* move in new values */
> PartOpr.EstProdHours = AveProd
> PartOpr.EstSetHours = AveSet.
> /* update values */
> UPDATE
> PartOpr.Number01
> PartOpr.Number02
> end.
> end.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/files/.<
> http://groups.yahoo.com/group/vantage/files/>
> <http://groups.yahoo.com/group/vantage/files/>
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
