That worked so perfect I can't even begin to thanks you.
Thank you very very much.
Jeremy Leonard
IT Manager
K-T Corporation
Sent: Tuesday, November 04, 2003 5:06 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Help with VB Form data
Instead of trying to populate more fields on the VBForm (Sales Order #),
just create a .p file to gather all the information you need, format it in
the correct string and launch your app:
DEF VAR data AS CHARACTER.
FIND FIRST OrderHed where (rowid(OrderHed) = GetCurrentRowID()) no-lock.
ASSIGN data = data + "~" + STRING(OrderHed.OrderNum).
FIND FIRST Customer WHERE Customer.CustNum = OrderHed.CustNum NO-LOCK.
ASSIGN data = data + "~" + Customer.Name + "~" + STRING(OrderHed.CustNum).
My syntax may be a bit off cause I typed this from memory, but it works
really well.
Sent: Tuesday, November 04, 2003 1:13 PM
Subject: [Vantage] Help with VB Form data
I am trying to launch our document imaging application from a VB Form. I
don't know if my brain is so Microsoft oriented now that I cant figure this
out or what. I need to supply it with several parameters.
As an example, I am trying to launch an app from the Sales Order VB Form. I
need to supply the program with a command line that will look like this.
v:\ud\myapp.exe jleonard~SO~23890~Boeing~113
jleonard=vantage user name
SO=Type of Document being Scanned
23890=Sales Order Number
Boeing=Customer Name
113=CustNum
I was able to get the user name and Type of Document easy. What I cant
figure out is how to get the last three variables.
I tried this in a .p file to just get the Sales Order Number but I keep
getting an error.
setdecimalvalue("OrderHed.NUMBER-FIELD_1.SCRVALUE":U,Orderhed.ordernum)
no-error.
RETURN.
I was thinking that if I could at least get the Sales Order number into a
field on the VB Form I could go from there. I would prefer just to load the
sales order number into a variable that I can pass to the command line.
Any help would be greatly appreciated.
FRUSTRATED
Jeremy Leonard
IT Manager
K-T Corporation
really well.
113=CustNum
getting an error.
no-error.
RETURN.
FRUSTRATED
