Is there anyway to copy a VB form from a test database to a live database?
If so can someone tell me where to find the file.
Fredy Venczel
Fredy Venczel
----- Original Message -----
Sent: Thursday, April 11, 2002 7:53 AM
Subject: [Vantage] VB Forms
Is it possible to "pull" data into a VB form from the database? For example, I'm creating a VB form for Quotehed. I would like to have a company field, due date field, and RFQ field all on the form. But I would like to have the data automatically pull in from the Quote header so that way there is no extra typing. Is this possible?
Also, besides screen print and using crystal or RB is it possible to print VB forms?
Thanks everyone!
Wendy Bowen
Network Administrator
Schmald Tool & Die, Inc.
Burton, Michigan
(810) 743-1600 ext.323
wpursche@...
VB forms?
Thanks everyone!
Wendy Bowen
Burton, Michigan
wpursche@...
>Couldn't you put some extra logic in to only update the field when blank ?VantageBasic doesn't support logic.
VB forms?
Thanks everyone!
Wendy Bowen
Burton, Michigan
wpursche@...
Sent: Thursday, April 11, 2002 6:58 PM
Subject: RE: [Vantage] VB Forms
Sent: Friday, 12 April 2002 3:50 AM
Subject: Re: [Vantage] VB Forms
Wendy,
To answer your first question, yes, you can pull in data from Progress to
your VB Form. Sarah Verishi helped me figure this out for the OrderRel
Table as follows:
-Insert a field of the type you need onto the Form.
-From within the VBForms Form Designer window, double-click somewhere on the
grayspace on the form (not a specific field).
-Next to the 'Commands' filed, set it to 'On Entry'.
-In the white space, enter the following:
set DATE-FIELD_1.scrvalue={OrderRel.NeedByDate.scrvalue}
This fills in that field automatically when you open up the VBForm. I ended
up not using this in my case because of the following: if the default value
wasn't what needed to be entered, you could override it. But if you needed
to go back to the VBForm later, it would once again insert the original date
again.
You may be able to translate this into what you need for the QuoteHed table.
Troy Funte
Liberty Electronics
VB forms?
Thanks everyone!
Wendy Bowen
Burton, Michigan
wpursche@...
Yahoo! Groups Sponsor
ADVERTISEMENT
To: <vantage@yahoogroups.com>
Sent: Thursday, April 11, 2002 3:58 PM
> From: Troy Funte [mailto:tfunte@...]
> Wendy,
to
> Table as follows:
the
ended
value
date
> again.
table.
> Troy Funte
> Liberty Electronics
> From: Wendy Bowen (Pursche)
> VB forms?
> Thanks everyone!
> Wendy Bowen
> Burton, Michigan
> wpursche@...
Wendy,
to
Table as follows:
the
ended
value
date
again.
table.
Troy Funte
Liberty Electronics
VB forms?
Thanks everyone!
Wendy Bowen
Burton, Michigan
wpursche@...
ADVERTISEMENT
ADVERTISEMENT
<http://rd.yahoo.com/M=194081.1994012.3473453.1261774/D=egroupweb/S=17050071
83:HM/A=1036972/R=0/*http://www.ediets.com/start.cfm?code=3466> Click Here!
<http://us.adserver.yahoo.com/l?M=194081.1994012.3473453.1261774/D=egroupmai
l/S=1705007183:HM/A=1036972/rand=924486929>
Sent: Friday, May 17, 2002 11:24 AM
Can I do a calculation within VB Forms? I have 8 number fields in my VB
Forms. I want to total them and put the total into a ninth number field by
the user clicking a 'total' button. I can't seem to figure it out. I know
how to use the set command and can get the button to make the ninth field
equal the contents of one of the other fields but can't figure out how to
get it to add multiple fields together within that command window. Anybody
know how to do this?
Thanks!
-Sarah
ADVERTISEMENT
