If I am not mistaken is should be something like this...
ShipHed.ShipDate + Part.LotShelfLife COLUMN-LABEL "ExpiryDate"
This will handle everything that ships as a Part Number.
You may have to add logic to handle the non part numbers...
Good luck,
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of joeynsknew
Sent: Wednesday, September 14, 2005 9:57 AM
Subject: [Vantage] How to sum up a date field in BAQ in Vantage 8.0.
Dear all,
I'm trying to create a calculation field by using BAQ in Vantage 8.0.
I want to sum up a date field with a numeric field and expect to return
a result in date format.
For example, I'd like to create a calculated Date (say "ExpiryDate") by
adding "Part.LotShelfLife"(Numeric) to "ShipHed.ShipDate"(Date) after
linking up all the related tables; however syntax error is returned.
Can anyone give me some advice?
Thanks a lot.
Gina
Yahoo! Groups Links
Good luck,
Aaron Hoyt
Vantage Plastics
Of joeynsknew
Dear all,
Thanks a lot.
Gina
Yahoo! Groups Links
