How to Sync Dataset from RDD to Bartender MAP File
Hi Guys,
I am new to Bartender here so could you guys help me with couple of Questions.
I am Trying to Sync a Dataset for my Job traveler report I created the duplicate report and selected the report type as Bartender Labels.
Next I have a client installed on my local System .
1) I have a Report which prints the tags correctly and this is the report I need a copy of
2) I put the same report Style details to my new report including the report location(with New BTW File name) and Output location is same as previous report.
3) Now I go to Job traveler and Click on Generate Only, But there is no file generated in the output location which I added in report style.
The Help Here I need is How to I get the MAP File created if someone has a reference or video to create Bartender report using RDD (BASE REPORT) using It would be really helpful to me
Map file can only be created by printing the report. There are more details on how to do it on this forum. You should be able to find it.
I cover this pretty thoroughly (70 pages) here:
https://www.epiusers.help/t/how-to-print-from-epicor-using-bartender/89143
