We just recently did this and except for the Progress Explorer tool issue,
everything went fine. I did run across one problem later on, but it had nothing
to do with Windows 2008R2. To make the transition go smoothly, I created a new
Vantage client folder on each workstation with a differnt name then the one for
the old server (I called it ERP803). On Monday, after I switched everything
over to the new server over the weekend, I had everyone log in using the
new vantage Icon for their ERP803 folder. Everything went fine until I decided
they no longer needed the old client803 folder on the workstations. What I
didn't realize is that the custom menu items I added over the years contain the
path to the old folder. It was an easy fix, I just went down though the list of
all menu items and when I found a path I just deleted it and left the DLL file
name.
Sent: Wed, March 9, 2011 4:21:57 PM
Subject: [Vantage] Re: Installing V8.03.409C on 2008 R2 x64 Std Server
Â
Yes. We are planning on moving our Vantage 8.03.409c off of Server 2003 to 2008
R2 x64 Standard Edition.
Is there anything I need to watch out for?
name.
Â
--- In vantage@yahoogroups.com, "cubcrafters_it" <jason.navarrete@...> wrote:
> Are you installing 32-bit Epicor?
> I had to use that registry fix to get the Progress Explorer Tool to run (search
>should bring up that thread again), and I never did try the newer OpenEdge tools
>after it hung up on me a couple of times, but no other big issues.
> Curious to know how it goes for you.
> --- In vantage@yahoogroups.com, "randyduly" <randy.duly@> wrote:
> > Hello everyone-
> > We are installing V8.03.409C (Progress DB) on Windows Server 2008 R2 x64 Std
>edition this weekend. Are there any gotacha or any thing that we need to look
>out for.
> > I have installed V8.03.409c in a 32-bit environment many times, but not in a
>64-bit environment.
> > I did someone mention something about the Progress Explorer Tool. Is there
>any problem using that in a 64-bit environment?
> > Thanks in advance for any info.
> > Randy Duly
