Should this work the same with version 6.1?
Rob Fiddelke
International Cybernetics Corp.
Of Paul Wetherington
Sent: Wednesday, February 28, 2007 9:25 AM
Subject: RE: [Vantage] Integrate Crystal Reports
Are you looking to add a custom report that you have written into the
menu structure of Vantage? If this is the case then you will need to
follow the following menu path (Version 8.03D):
System Management / Security Maintenance / Menu Maintenance
From here you will want to select the appropriate folder for where you
want to run the report and select 'add new menu' from the toolbar. Each
new menu item has to have it own custom Menu ID which begins with 'UD'
followed by the name that will appear on the menu structure, as well as
a security ID. Be sure to check the enabled box or the report will not
fire off in Vantage.
Under the program section select 'Custom Report Link' as the program
type and then select a report Icon. When you select custom report link
the following program should default ' Epicor.Mfg.UI.CustomReport.dll',
if this does not appear you will have to type it in for the report to
work properly. The final step is to type in the path for the actual
custom report and then save your new menu item.
Once you have saved you new menu item you will have to log off of
Vantage and re-login for the changes to appear.
Hope this helps.
Paul Wetherington
Karlee, Inc.
Behalf Of Rob Fiddelke
Sent: Tuesday, February 27, 2007 8:22 PM
Subject: [Vantage] Integrate Crystal Reports
I'm looking to integrate a Crystal Report into the report menu.
Can someone get me going in the right direction?
I have read some other posts that suggest that this can be accomplished.
Rob Fiddelke
Yahoo! Groups Links
Rob Fiddelke
Hope this helps.
Paul Wetherington
Karlee, Inc.
Rob Fiddelke
Yahoo! Groups Links
