I use this option all the time. it works great!!
Judd
Custom Hoists, Inc.
Ph: (419) 368-4721 EXT. 246
Sent: Friday, January 16, 2004 11:00 AM
Subject: RE: [Vantage] Compiled Crystal Reports 8.5
Norm,
Epicor sent me this informaiton on how to put crystal reports in the vantage
menu using .w procedure file. This may or may not help your cause. Here is
the genereal information but I also uploadeded the document to the
Yahoo/Vantage site.
Jasper
How to add a compiled Crystal Report as a Vantage menu option.
The following procedure will allow you to call a compiled Crystal Report
(.EXE) from a Vantage menu option. This will allow you to use Vantage menu
security to control user access to these reports.
Step #1: Create a Progress program (.W) file to call the Crystal Report
..EXE.
This program (.W) file would contain the following code:
DEFINE VARIABLE ProgNamePath as CHARACTER NO-UNDO.
DEFINE VARIABLE ReturnCode AS INTEGER NO-UNDO.
PROCEDURE WinExec EXTERNAL "KERNEL32.DLL":
DEFINE INPUT PARAMETER ProgramName AS CHARACTER.
DEFINE INPUT PARAMETER VisualStyle AS LONG.
DEFINE RETURN PARAMETER StatusCode AS LONG.
END PROCEDURE.
Set the ProgNamePath variable value to the location\Crystal Report's .EXE
ProgNamePath = "W:\Vantage\UD\Scrap By Reason Detail.exe".
RUN WinExec (INPUT ProgNamePath, INPUT 1, OUTPUT ReturnCode).
The example above shows how a "Scrap By Reason Detail.Exe" would be called.
Include the full path to the compile report .exe.
Save this file as UD<Compile ReportName>.W and eliminate the spaces.
For example: Scrap By Reason Detail.exe "save as" UDScrapByReasonDetail.w
Step #2: Copy the UD<Compile ReportName>.W file to the \Vantage\UD folder.
Step #3: Use Vantage Menu Structure Maintenance to add a new menu option to
call the UD<Compile ReportName>.W
Note: Menu ID must start with UD. Any naming convention for the remaining
characters can be used.
Program must always include UD/UD<Compile Report Name>.W
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
Judd
Custom Hoists, Inc.
Norm,
Yahoo/Vantage site.
Jasper
..EXE.
END PROCEDURE.
_____
Yahoo! Groups Links
