<div id="ygrps-yiv-107850048yiv6812643624ygrp-text">
<div></div><div style="color:#000;background-color:#fff;font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"><div><span>Great! Thank you.</span></div><div><span><br clear="none"></span></div><div dir="ltr" id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455638334213_7139"><span>I thought I would have to upgrade from 9.05.506B > 9.05.700 > 9.05.702a but if I can go directly from from 506B to 702a, that works for me! </span></div><div dir="ltr" id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455638334213_7139"><span><br clear="none"></span></div><div dir="ltr" id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455638334213_7139"><span>-Anthony</span></div> <div class="ygrps-yiv-107850048yiv6812643624qtdSeparateBR"><br clear="none"><br clear="none"></div><div class="ygrps-yiv-107850048yiv6812643624yqt4998619747" id="ygrps-yiv-107850048yiv6812643624yqt14059"><div class="ygrps-yiv-107850048yiv6812643624yahoo_quoted" style="display:block;"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"> <div dir="ltr"><font size="2" face="Arial"> On Tuesday, February 16, 2016 11:34 AM, "Jonathan Lang lsbestinc@... [vantage]" <vantage@yahoogroups.com> wrote:<br clear="none"></font></div> <br clear="none"><br clear="none"> <div class="ygrps-yiv-107850048yiv6812643624y_msg_container"><div id="ygrps-yiv-107850048yiv6812643624"><div>
<div></div><div style="color:#000;background-color:#fff;font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"><div id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44675"><span></span></div><div></div><div dir="ltr" id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44676">Are on Progress or SQL? </div><div dir="ltr" id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44676"><br clear="none"></div><div dir="ltr" id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44676">If you're on Progress you need updates 102aSP3, rl102ASP0329hf, SP905702-P.exe, and PA905702A-P. </div><div dir="ltr" id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44676"><br clear="none"></div><div dir="ltr" id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44676">For SQL you need the SQL versions of each patch. </div><div dir="ltr" id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44676"><br clear="none"></div><div dir="ltr" id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44676">Make sure you run your 10080 Conversion from your Admin Tools before you upgrade to 702A. That is VERY IMPORTANT!!! Download the upgrade guide and follow it to the 'T' for the patches. 10080 gets done BEFORE 702 UPGRADE though!!</div><div dir="ltr" id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44676"><br clear="none"></div><div dir="ltr" id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44676">Other than that you should be good.</div><div id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44676"><br clear="none"></div><div id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44676"><br clear="none"></div><div class="ygrps-yiv-107850048yiv6812643624signature" id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44678"><div id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44677"><span style="color:rgb(0, 0, 255);"><span style="background-color:rgb(255, 255, 255);"><span style="font-weight:bold;">Jonathan Lang</span></span></span><br clear="none"></div><div id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44679" style="color:rgb(0, 0, 0);font-size:13px;font-family:arial, helvetica, clean, sans-serif;background-color:transparent;font-style:normal;"><span style="font-weight:bold;">I.T Manager</span></div><div id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44680" style="color:rgb(0, 0, 0);font-size:13px;font-family:arial, helvetica, clean, sans-serif;background-color:transparent;font-style:normal;"><span id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_45109" style="font-weight:bold;">Database Engineer</span><br clear="none"></div><div id="ygrps-yiv-107850048yiv6812643624yui_3_16_0_1_1455553859358_44681" style="color:rgb(0, 0, 0);font-size:13px;font-family:arial, helvetica, clean, sans-serif;background-color:transparent;font-style:normal;"><br clear="none"></div></div> <div class="ygrps-yiv-107850048yiv6812643624qtdSeparateBR"><br clear="none"><br clear="none"></div><div class="ygrps-yiv-107850048yiv6812643624yahoo_quoted"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"> <div dir="ltr"><font size="2" face="Arial"> On Tuesday, February 16, 2016 9:58 AM, "ascalzitti1989@... [vantage]" <vantage@yahoogroups.com> wrote:<br clear="none"></font></div> <br clear="none"><br clear="none"> <div class="ygrps-yiv-107850048yiv6812643624y_msg_container"><div id="ygrps-yiv-107850048yiv6812643624"><div>
<div></div><div><span>I am going to upgrade from 9.04.506B to 9.05.702a. I do not believe I can go straight from our current version to 702a. Can someone tell me the intermediate version that will be needed when moving from 506B to 702a.</span></div><div><span><br clear="none"></span></div><div>Thanks, </div><div> Anthony</div>
</div>
<div style="color:#fff;height:0;"></div></div>
</div>
</div>
<div class="ygrps-yiv-107850048yiv6812643624yqt4998619747" id="ygrps-yiv-107850048yiv6812643624yqt17111"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-mkp #ygrps-yiv-107850048yiv6812643624hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-mkp #ygrps-yiv-107850048yiv6812643624ads {
margin-bottom:10px;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-mkp .ygrps-yiv-107850048yiv6812643624ad {
padding:0 0;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-mkp .ygrps-yiv-107850048yiv6812643624ad p {
margin:0;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-mkp .ygrps-yiv-107850048yiv6812643624ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-sponsor #ygrps-yiv-107850048yiv6812643624ygrp-lc {
font-family:Arial;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-sponsor #ygrps-yiv-107850048yiv6812643624ygrp-lc #ygrps-yiv-107850048yiv6812643624hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-sponsor #ygrps-yiv-107850048yiv6812643624ygrp-lc .ygrps-yiv-107850048yiv6812643624ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624activity span {
font-weight:700;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624activity span span {
color:#ff7900;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624activity span .ygrps-yiv-107850048yiv6812643624underline {
text-decoration:underline;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 .ygrps-yiv-107850048yiv6812643624attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 .ygrps-yiv-107850048yiv6812643624attach div a {
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 .ygrps-yiv-107850048yiv6812643624attach img {
border:none;padding-right:5px;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 .ygrps-yiv-107850048yiv6812643624attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 .ygrps-yiv-107850048yiv6812643624attach label a {
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 .ygrps-yiv-107850048yiv6812643624bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 .ygrps-yiv-107850048yiv6812643624bold a {
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 dd.ygrps-yiv-107850048yiv6812643624last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 dd.ygrps-yiv-107850048yiv6812643624last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 dd.ygrps-yiv-107850048yiv6812643624last p span.ygrps-yiv-107850048yiv6812643624yshortcuts {
margin-right:0;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 div.ygrps-yiv-107850048yiv6812643624attach-table div div a {
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 div.ygrps-yiv-107850048yiv6812643624attach-table {
width:400px;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 div.ygrps-yiv-107850048yiv6812643624file-title a, #ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 div.ygrps-yiv-107850048yiv6812643624file-title a:active, #ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 div.ygrps-yiv-107850048yiv6812643624file-title a:hover, #ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 div.ygrps-yiv-107850048yiv6812643624file-title a:visited {
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 div.ygrps-yiv-107850048yiv6812643624photo-title a, #ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 div.ygrps-yiv-107850048yiv6812643624photo-title a:active, #ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 div.ygrps-yiv-107850048yiv6812643624photo-title a:hover, #ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 div.ygrps-yiv-107850048yiv6812643624photo-title a:visited {
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 div#ygrps-yiv-107850048yiv6812643624ygrp-mlmsg #ygrps-yiv-107850048yiv6812643624ygrp-msg p a span.ygrps-yiv-107850048yiv6812643624yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 .ygrps-yiv-107850048yiv6812643624green {
color:#628c2a;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 .ygrps-yiv-107850048yiv6812643624MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 o {
font-size:0;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624photos div {
float:left;width:72px;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624reco-category {
font-size:77%;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624reco-desc {
font-size:77%;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 .ygrps-yiv-107850048yiv6812643624replbq {
margin:4px;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-mlmsg select, #ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 input, #ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-mlmsg pre, #ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 code {
font:115% monospace;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-mlmsg #ygrps-yiv-107850048yiv6812643624logo {
padding-bottom:10px;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-msg p#ygrps-yiv-107850048yiv6812643624attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-reco #ygrps-yiv-107850048yiv6812643624reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-sponsor #ygrps-yiv-107850048yiv6812643624ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-sponsor #ygrps-yiv-107850048yiv6812643624ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-sponsor #ygrps-yiv-107850048yiv6812643624ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-text {
font-family:Georgia;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-text tt {
font-size:120%;}
#ygrps-yiv-107850048 #ygrps-yiv-107850048yiv6812643624 #ygrps-yiv-107850048yiv6812643624ygrp-vital ul li:last-child {
border-right:none !important;}
