Is there a setting someplace that would allow the current inventory qty in the bin to show on the count tickets generated in the cycle count process
There is not a setting for this, however the frozen inventory value is stored in the CCtagdtl table and should be easy enough to add to the count tags.
That’s what it looked like. Thank you for the response.
The concept of a physical inventory is that this should be a blind count. The counter should not care how many the system thinks are there. They are already being given a “hint” that a specific part number is found in a specific location. Once they enter the count, then if there is a discrepancy, the system will tell you to do a recount to check again.
