Hi, we are getting the following error when running the Inventory WIP Reconciliation Report for “Only Unposted to the G/L” When we run “Only Posted to the G/L” the report runs fine. Epicor has been unable to provide a solution so I thought I’d check to see if anyone here has run into this before. Is it the volume of open jobs perhaps?
Error: System.Threading.ThreadAbortException: Thread was being aborted.
at SNIReadSyncOverAsync(SNI_ConnWrapper* , SNI_Packet** , Int32 )
at SNINativeMethodWrapper.SNIReadSyncOverAsync(SafeHandle pConn, IntPtr& packet, Int32 timeout)
at System.Data.SqlClient.TdsParserStateObject.ReadSniSyncOverAsync()
at System.Data.SqlClient.TdsParserStateObject.TryReadNetworkPacket()
at System.Data.SqlClient.TdsParserStateObject.TryPrepareBuffer()
at System.Data.SqlClient.TdsParserStateObject.TryReadByte(Byte& value)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method) at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior) at System.Data.Entity.Infrastructure.Interception.InternalDispatcher1.Dispatch[TTarget,TInterceptionContext,TResult](TTarget target, Func3 operation, TInterceptionContext interceptionContext, Action3 executing, Action3 executed) at System.Data.Entity.Infrastructure.Interception.DbCommandDispatcher.Reader(DbCommand command, DbCommandInterceptionContext interceptionContext) at System.Data.Entity.Core.EntityClient.Internal.EntityCommandDefinition.ExecuteStoreCommands(EntityCommand entityCommand, CommandBehavior behavior) at System.Data.Entity.Core.Objects.Internal.ObjectQueryExecutionPlan.Execute[TResultType](ObjectContext context, ObjectParameterCollection parameterValues) at System.Data.Entity.Core.Objects.ObjectContext.ExecuteInTransaction[T](Func1 func, IDbExecutionStrategy executionStrategy, Boolean startLocalTransaction, Boolean releaseConnectionOnSuccess)
at System.Data.Entity.Core.Objects.ObjectQuery1.<>c__DisplayClass7.<GetResults>b__5() at System.Data.Entity.Core.Objects.ObjectQuery1.GetResults(Nullable1 forMergeOption) at System.Data.Entity.Core.Objects.ObjectQuery1.<System.Collections.Generic.IEnumerable.GetEnumerator>b__0()
at System.Data.Entity.Internal.LazyEnumerator1.MoveNext() at System.Linq.Enumerable.Single[TSource](IEnumerable1 source)
at System.Data.Entity.Core.Objects.CompiledQuery.ExecuteQuery[TResult](ObjectContext context, Object[] parameterValues)
at System.Data.Entity.Core.Objects.CompiledQuery.Invoke[TArg0,TArg1,TArg2,TResult](TArg0 arg0, TArg1 arg1, TArg2 arg2)
at Epicor.Data.DBExpressionCompiler.GetResult[TDataContext,TQuery,TResult](Func3 executeQuery, Cache cacheSetting, TDataContext dataContext, TQuery query) in C:\_Releases\ICE\UD10.2.500.16FW\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 445 at Epicor.Data.DBExpressionCompiler.InvokeSingle[TDataContext,TQuery,TResult](Expression expression, Cache currentCacheSetting, Boolean cacheQuery, TDataContext dataContext, Func2 getDataCacheKey, Func2 compileQuery, Func3 executeQuery) in C:_Releases\ICE\UD10.2.500.16FW\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 306
at Epicor.Data.DBExpressionCompiler.<>c__DisplayClass34_0`4.b__0(TContext context, TArg1 arg1, TArg2 arg2) in C:_Releases\ICE\UD10.2.500.16FW\Source\Framework\Epicor.System\Data\DBExpressionCompiler.Generated.cs:line 1110
at Erp.Internal.PE.COSAndWIPPre_Post.BuildTWip() in C:_Releases\ERP\UD10.2.500.16\Source\Server\Internal\PE\CosAndWip\CostCalculation.cs:line 853
at Erp.Internal.PE.COSAndWIPPre_Post.RunProcess() in C:_Releases\ERP\UD10.2.500.16\Source\Server\Internal\PE\CosAndWip\COSAndWIPPre_Post.cs:line 639
at Erp.Internal.PE.Pre_PostBase._RunProcess(Int64 instance_TaskNum, String groupID, PostingMode mode, Boolean skipPEDataInit) in C:_Releases\ERP\UD10.2.500.16\Source\Server\Internal\PE\Pre_PostBase\Pre_PostBase.cs:line 173
“Epicor102500-Test”: A communication error occurred trying to run task ID 4979666 for agent “SystemTaskAgent” on the application server (User: “rnewell”, Task Description: “Inventory WIP Reconciliation Report”).
If this continues to happen investigate if you need to increase the receive and send timeouts in your web.config.
Error details:
System.ServiceModel.CommunicationException: The server did not provide a meaningful reply; this might be caused by a contract mismatch, a premature session shutdown or an internal server error.
Server stack trace:
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Ice.Contracts.RunTaskSvcContract.RunTask(Int64 ipTaskNum)
at Ice.Proxy.Lib.RunTaskImpl.RunTask(Int64 ipTaskNum) in C:_Releases\ICE\RL10.2.500.0FW\Source\Shared\Contracts\Lib\RunTask\RunTaskImpl.cs:line 147
at Ice.TaskAgentCore.ServiceCaller.<>c__DisplayClass34_0.<RunTask_RunTask>b__0(RunTaskImpl impl)
at Ice.TaskAgentCore.ImplCaller.RunTaskImplCaller1.<>c__DisplayClass4_0.<Call>b__0(TImpl impl) at Ice.TaskAgentCore.ImplCaller.RunTaskImplCaller1.Call[TResult](Func2 doWork, ExceptionBehavior communicationExceptionBehavior, ExceptionBehavior timeoutExceptionBehavior) at Ice.TaskAgentCore.ImplCaller.RunTaskImplCaller1.Call(Action`1 doWork, ExceptionBehavior communicationExceptionBehavior, ExceptionBehavior timeoutExceptionBehavior)
at Ice.TaskAgentCore.ServiceCaller.RunTask_RunTask(Int64 sysTaskNum, ExceptionBehavior communicationExceptionBehavior, ExceptionBehavior timeoutExceptionBehavior)
at Ice.TaskAgentCore.ScheduleProcessor.CallServiceAction(SysTaskRow sysTaskRecord, SysTaskParamRow companyParamRecord, ServiceCallArguments serviceCallArguments)
