Invoice Group Help
We received the same error yesterday on 607b when trying to print the edit list.  We had logged the same problem back in 2012.  According to Support's response back then, it was supposedly fixed in 700.
Our issue related to re-using an invoice group that had been used in the past, i.e. probably in the previous year or so.  To correct, try moving several of the problem invoices to a new group, if it works, then move the remaining invoices:
- create a new group, one that you're sure hasn't been used in the past
- open the problem group
- select a problem invoice
- select Actions | Invoice | Transfer and select the new, unique group (if the problem group has only one invoice, you may get an 'index -1' error; try loading the target group anyway, the invoice should still have moved).
- open the new group and try calculating taxes and printing an edit list
Hope that helps.
Bob Beaghan
9.05.700B SQL – Non-Unicode
Hello all, having an issue we have yet to come across.  I think it may be related to the Tax issue some of us were experiencing with AvaTax.  I have one group of invoices (have cleared the group and re-created), that just will not acknowledge that tax has been calculated.  We keep getting the following error when attempting to pull the Edit List:
Exception caught in: Epicor.Mfg.Rpt.ARInvEdit
Error Detail
Message: Taxes need to be calculated before printing.
Type: Error
Program: Rpt/ARInvEdit/ARInvEdit.p
Method: ExValidateParam
Table: InvcDtl
Row:
Field: TaxConnectCalc
Stack Trace
   at Epicor.Mfg.Proxy.ARInvEditImpl.SubmitToAgent(ARInvEditDataSet ds, String agentID, Int32 agentSchedNum, Int32 agentTaskNum, String maintProgram)
   at Epicor.Mfg.UI.Adapters.ARInvEditAdapter.SubmitToAgent(String agentID, Int32 angetSchedNum, Int32 agentTaskNum)
   at Epicor.Mfg.UI.Rpt.ARInvEdit.Transaction.adapterSubmitToAgent(String agentID, Int32 angetSchedNum, Int32 agentTaskNum)
   at Epicor.Mfg.UI.FrameWork.EpiReportTransaction.SubmitToAgent(String agentID, Int32 angetSchedNum, Int32 agentTaskNum)
Anyone run into a similar issue, or know how to get around it?  I can view all the Tax Connect results for each invoice and see that the operation was successful.  So I’m not sure what field Epicor is keying off of to determine whether the tax has been calculated or not.
Obviously we have Tax Connect back up and running, and are able to close other groups, just this one particular group is being difficult.
Any help would be greatly appreciated.
Jason Doyle
CONFIDENTIALITY NOTICE: This e-mail communication and any attachments may contain confidential and privileged information for the use of the designated recipients named above. If you are not the intended recipient, you are hereby notified that you have received this communication in error and that any review, disclosure, dissemination, distribution or copying of it or its contents is prohibited. If you have received this communication in error; please notify the author with an e-mail reply or immediately by telephone at 614-431-8000 or 800-288-3475 and destroy all copies of this communication and any attachments.
