This is pretty simple code that I’ve used a hundred times before with different adapters. Have I overlooked something?
The where clause does not seem to be working.
public DataSet GetJob(string jobNum)
bool more;
JobPartAdapter jpAdapter = new JobPartAdapter(oTrans);
jpAdapter.BOConnect();
SearchOptions opts = new SearchOptions(SearchMode.AutoSearch);
opts.PageSize = 20; //return this many
string where = string.Format("JobNum = '{0}'", jobNum);
opts.NamedSearch.WhereClauses.Add("job", where);
var jobs = jpAdapter.GetRows(opts, out more);
return jobs;
What exactly is failing?
Edit: I guess I should read a little slower
Have you tried passing this job num into the BL tester and writing your whereClause there to see what it returns?
Inner Exception:
A call to SSPI failed, see inner exception.
Server stack trace:
at System.ServiceModel.Channels.WindowsStreamSecurityUpgradeProvider.WindowsStreamSecurityUpgradeInitiator.OnInitiateUpgrade(Stream stream, SecurityMessageProperty& remoteSecurity)
at System.ServiceModel.Channels.StreamSecurityUpgradeInitiatorBase.InitiateUpgrade(Stream stream)
at System.ServiceModel.Channels.ConnectionUpgradeHelper.InitiateUpgrade(StreamUpgradeInitiator upgradeInitiator, IConnection& connection, ClientFramingDecoder decoder, IDefaultCommunicationTimeouts defaultTimeouts, TimeoutHelper& timeoutHelper)
at System.ServiceModel.Channels.ClientFramingDuplexSessionChannel.SendPreamble(IConnection connection, ArraySegment`1 preamble, TimeoutHelper& timeoutHelper)
at System.ServiceModel.Channels.ClientFramingDuplexSessionChannel.DuplexConnectionPoolHelper.AcceptPooledConnection(IConnection connection, TimeoutHelper& timeoutHelper)
at System.ServiceModel.Channels.ConnectionPoolHelper.EstablishConnection(TimeSpan timeout)
at System.ServiceModel.Channels.ClientFramingDuplexSessionChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.CommunicationObject.Open()
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at System.ServiceModel.ICommunicationObject.Open()
at Epicor.ServiceModel.Channels.ChannelEntry1.CreateNewChannel() at Epicor.ServiceModel.Channels.ChannelEntry1.CreateChannel()
at Epicor.ServiceModel.Channels.ChannelEntry1.GetContract() at Epicor.ServiceModel.Channels.ImplBase1.GetChannel()
at Epicor.ServiceModel.Channels.ImplBase`1.HandleContractBeforeCall()
at Ice.Proxy.BO.UserFileImpl.GetRows(String whereClauseUserFile, String whereClauseUserComp, String whereClauseUserCompExt, Int32 pageSize, Int32 absolutePage, Boolean& morePages)
Inner Exception:
at System.Net.Security.NegoState.StartSendAuthResetSignal(LazyAsyncResult lazyResult, Byte[] message, Exception exception)
at System.Net.Security.NegoState.StartSendBlob(Byte[] message, LazyAsyncResult lazyResult)
at System.Net.Security.NegoState.CheckCompletionBeforeNextSend(Byte[] message, LazyAsyncResult lazyResult)
at System.Net.Security.NegoState.ProcessReceivedBlob(Byte[] message, LazyAsyncResult lazyResult)
at System.Net.Security.NegoState.StartReceiveBlob(LazyAsyncResult lazyResult)
at System.Net.Security.NegoState.CheckCompletionBeforeNextReceive(LazyAsyncResult lazyResult)
at System.Net.Security.NegoState.ProcessAuthentication(LazyAsyncResult lazyResult)
at System.Net.Security.NegotiateStream.AuthenticateAsClient(NetworkCredential credential, ChannelBinding binding, String targetName, ProtectionLevel requiredProtectionLevel, TokenImpersonationLevel allowedImpersonationLevel)
at System.Net.Security.NegotiateStream.AuthenticateAsClient(NetworkCredential credential, String targetName, ProtectionLevel requiredProtectionLevel, TokenImpersonationLevel allowedImpersonationLevel)
Inner Exception:
The target principal name is incorrect
Perhaps on an unrelated note, when I VPN in from home now I can’t use my local Epicor client, (used to work) it never authenticates - I have to remote into my work PC.
