Is it possible to make an editable field in a Dashboard gridview
No
A Mercer Sisson
Systems Manager - Insaco Inc
ams@...
215-536-3500 x 523
267-733-0641 (direct)
215-285-0332 (cell)
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Dan Godfrey
Sent: Friday, January 27, 2012 12:09 PM
Subject: RE: [Vantage] Is it possible to make an editable field in a Dashboard gridview?
I am using Vantage 8 . . .409C. Is there any hope?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Kent Rooen
Sent: Friday, January 27, 2012 9:08 AM
If you are using Epicor 9.05 you can use an updatable dashboard and make a field in the dashboard edit enabled.
Date: Fri, 27 Jan 2012 16:58:32 +0000
Subject: [Vantage] Is it possible to make an editable field in a Dashboard gridview?
I have a dashboard set up in MES and I need to give the leads the ability to edit a JobOper.comment field that I have in the gridview.
So is an editable field in the gridview possible?
That functionality was not built in until Epicor 9.05 Sorry
Date: Fri, 27 Jan 2012 17:09:11 +0000
Bummer ... I have seen people talk about have editable BAQs, is that because they were in E9?
Sent: Friday, January 27, 2012 9:11 AM
Instead of built-in Vantage dashboard functionality, you could consider creating an ASP web-dashboard and using ODBC to update whichever field you want.
Here’s a good product to EASILY create awesome looking ASP pages: www.asprunnerpro.com
Turn on IIS on a server, put ODBC on the same server, and use this to generate your dashboards. I do it all the time. Even though it uses your internet browser, you can still add it as a menu item from your Vantage menu.
My disclaimer: Be careful. :-)
But I do this all the time. For example, we want to edit notes on AR Invoices or UD fields in Job Entry for notes. Once the Job or Invoice is closed, you cannot get to those fields in the UI unless you open things back up. With this, I have a dashboard of Job or AR notes..... simple screen, Invoice or Job Num is read-only but the notes fields are editable.
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of Kent Rooen
To: mailto:vantage%40yahoogroups.com
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1901 / Virus Database: 2109/4768 - Release Date: 01/26/12
Sorry, wrong URL: http://xlinesoft.com/asprunnerpro/
Sent: Friday, January 27, 2012 12:59 PM
Subject: Re: [Vantage] Is it possible to make an editable field in a Dashboard gridview?
