Timing I agree with, but you only report labor on the last op when you
backflush. The way he stated his set up, they backflush all ops and
record only on the last op.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of gclauser
Sent: Thursday, October 01, 2009 3:52 PM
Subject: Re: [Vantage] Job cost confusion
Timing is the key as well as sequencing. If you are backflushing and
someone reports labor and quantity on OP 20 when OP 10 has yet to be
entered for example.
Greg
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of gclauser
Greg
Manasa Reddy wrote:
><mailto:manasa%40weldcoa.com>
> Here is what we discovered because we do the same thing but we are
> average costing.
> The BOM Cost report will tell you what the part costs at the time you
> run the report.
> The Job's estimated costs are the costs of the part at the time you
> create the job, and then the actuals on the job are the costs at the
> time you backflush. So between the time you create the job and you
> backflush the job your purchased parts might have different costs on
> them (which for us since we are average rings true).
> Now what it should do since you are standard might be a little
> different. But the timing of creating and backflushing are the same no
> matter what method you use.
> HTH,
> M. Manasa Reddy
> manasa@... <mailto:manasa%40weldcoa.com>
> P: 630-806-2000<mailto:vantage%40yahoogroups.com>
> F: 630-806-2001
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On
> Behalf<mailto:vantage%40yahoogroups.com>
> Of sgotschall
> Sent: Thursday, October 01, 2009 2:30 PM
> Subject: [Vantage] Job cost confusionoperation
> We are on Vantage 8.03.408a Progress.
> I am confused about the Bill of Material Cost Report. We use standard
> cost, and all our methods are backflushed except for the final
> which are quantity only. So my question is why is there such athe
> difference in costs between what I see on the BOM cost report and the
> cost as captured by the job. If nothing has changed in the part method
> from the time the job was completed, they should show almost exactly
> same cost.[Non-text portions of this message have been removed]
